Beocenter 2 clamper problem
This post has 7 Replies | 2 Followers
chti59
France
Posts 149
chti59 Posted: Thu, Dec 27 2018 11:02 AM
Hi
Just received this unit and when pluging in the unit the clamper opens, the cd lids lift and then closes then opens again but only half way and stays there.
I did not checked yet the service manual.
Looks like the unit does not know where the clamper state is or may be a worn belt that is not able to open the clamper full way or else.
Just posting in case someone had the problem and would speed up my repair search.
Happy holidays to all you B&O passionates.
Ingo
Da wo die Weser einen großen Bogen macht
Posts 147
Ingo replied on Thu, Dec 27 2018 11:14 AM
Hello
 maybe the belt of the cd-unit have to be replaced
 Ingo
BeoVision Eclipse 55“ wallmounted, BeoRemote One BT; BeoSound 9000(ex-weiss), BeoLab 9; BeoLab 8000 rot; Beosound 1 grün; BeoPlay H6; Beo4
Ingo
Posts 147
Ingo replied on Thu, Dec 27 2018 2:23 PM
I speak about unit-Nr.: 9009; 2732004
The belt his most weak after several years
Check out the service manual
Ingo
Fritz
Posts 272
Fritz replied on Thu, Dec 27 2018 4:07 PM
Hi
Change the belt for the clamper and check lubrication on the gear where the belt is attached. The belt incl the belt wheels must be free of dirt and grease.
chti59
France
Posts 149
chti59 replied on Fri, Dec 28 2018 12:46 PM
Hi all
Thank you for your replies
I opened the unit and guess what ? someone tried before me and ripped the smd connector of the left clamper.
Some guys should not touch expensive goods like this and keep fooling around repairing their kids toys.
Will keep you posted if resoldering the connector stops the opening and closing behavior.
 Lucky the connector is not broken and I will be able to re-solder the SMD connector.
bigbruggsy
Posts 131
Silver Member
Hi all, I have the same issue with beocenter 2, any idea where I can buy the 2732004 belt? I've emailed a few places but i'm not getting any replies. I guess they don't have it?
Beolab 8000 x 2
Beolab 1
Beolab 2
Beovision 7-40
Beosound 9000
Beosound Ouverture
Beolit 12
beoboehm
Berlin
Posts 48
beoboehm replied on Thu, Apr 9 2020 11:12 AM
The belt in my BC2 is also on its way out.
I also e-mailed some places and got no response.
Maybe someone has info on the dimensions of the belt ?
flatwhite
Posts 49
flatwhite replied on Tue, Apr 21 2020 10:44 AM
How big of a job is it to change the belt?
Page 1 of 1 (8 items) | RSS
