Beolab Penta vs Beovox Redline 140 / RL 7000
This post has 40 Replies | 1 Follower
Stereomensch
Posts 322
Stereomensch Posted: Fri, Dec 28 2018 12:35 PM
Both are known as the best speakers of B&O from the 80ies.
Which one do you prefer and why?
DMacri
United States
Posts 881
DMacri replied on Sat, Dec 29 2018 12:31 AM
I have both and prefer the Pentas due to their easier placement and better sound quality.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Brian
California
Posts 72
Brian replied on Sat, Dec 29 2018 1:36 AM
I heard both on my Beosystem 7000 side by side, Beolab Pentas and RL 60s. Both speakers sound clear and perform well, but In my opinion, the Pentas carry more range, especially in the lower frequencies. I went with Penta IIIs and had them for several years. I eventually had to sell the Pentas due to a move, as they were just too big to take with me. I'm using Dali Zensors now, which are also nice. If I ever do come across a good pair of Pentas in the future, I'd be mightily tempted to take them on as a project.
Peter Pan
Posts 2,088
Peter Pan replied on Sat, Dec 29 2018 6:08 AM
Hi Stereomensch
I still love my BeoVox Penta - Now put PentaVox number 2 as the front speaker for 36 years.
Stereomensch
Posts 322
let's check out the specs :)
Rl 7000:
Net volume 38 litre
Frequency range +4 -8 dB 40 - 20,000 H (??)
Beolab Penta
Net volume 32 litres
Effective frequency range* 39 - 20,000 Hz
Can anyone help me? Why did B&O uses different methods ?
The Rl has a bigger net volume, so they should have a big sound? Am I right?
Peter Pan
Posts 2,088
Here, specifications of all Penta speakers.
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Jan 2 2019 7:11 PM
I have never heard the RL speakers described as the best of the 80s! The best were probably the MS150s though to be honest, the S45.2s, which were still around were ridiculously good for their size. Pentas lack real bass detail and I always felt RLs were muddy sounding - even the RL7000s. I love my Pentas though - bought a pair new and still have them.
Peter
Brian
California
Posts 72
Brian replied on Wed, Jan 2 2019 8:07 PM
Specs are fine, but it comes down to the sound. Why not just get both RLs and Pentas and try them out? Once you make up your mind, either sell the other ones, or use them for a multi-room setup.
Stereomensch
Posts 322
Those were the days :D
[image]https://abload.de/img/800b46a5-dc33-4280-bqafiz.jpeg[/image]
Stereomensch
Posts 322
Stereomensch
Posts 322
Yesterday I got a pair of the redlines. Too bad all sickens are broken.
already ordered the foam version at audiofriends.
has anyone a good advice for me what I should keep an eye on?
they don’t have an ABR. Is an Beomaster 7000 powerful enough?
DMacri
United States
Posts 881
DMacri replied on Mon, Jan 21 2019 7:36 AM
Make sure you use shims to help center the woofers. Lots of screws to remove in order to open them up. Yes, they are ported design, so no ABR to deal with. Once you have them refoamed you should be fine. They can handle 150W, but can sound fine with less. I wish I had the stands for mine. I just have them propped on the built in floor stands.
Dom
Stereomensch
Posts 322
And another one :)
Many users point out the redlines are difficult to place. Although this was their main selling point. Flexibility.
Does it make a difference, when placed vertikal, if the woofers are on top or should the bassreflex be on top ?
Or is it the best idea to use them in the horizontal position. I have the stands.
Peter Pan
Posts 2,088
Peter Pan replied on Tue, Jan 22 2019 9:07 AM
I'm to Penta, and here's a tip-
Units can be mounted mirrored, in right and left speakers.
DMacri
United States
Posts 881
DMacri replied on Tue, Jan 22 2019 9:20 AM
Peter Pan:
Tweeters towards the inside or outside?
Dom
DMacri
United States
Posts 881
DMacri replied on Tue, Jan 22 2019 9:22 AM
Stereomensch:
And another one :)
You lose some flexibility if you don’t have the stands. These speakers are wide, so I would go vertically with the woofers on the bottom. If there is too much floor bounce, I’d flip them over with woofers on the top.
Dom
Peter Pan
Posts 2,088
Peter Pan replied on Tue, Jan 22 2019 3:54 PM
DMacri
Here you can choose what sounds best in your room.
Normally facing right
Stereomensch
Posts 322
Questions over questions:
I have the version without the ABR.
But look at this, here is one guy who uses his speakers with two passive radiators:
Is a construction with passive membrans superior to an ordinary bassreflex system?
What do you think about this modification.
It could be found here:
http://90210seo.com/sweepstakes/SpeakerHobby.com/Peerless%20Tymphany%20830880%20passive%20radiator.htm
DMacri
United States
Posts 881
DMacri replied on Tue, Jan 22 2019 9:32 PM
Peter Pan:
DMacri
I thought I read elsewhere in the forum that they were all shipped as right speakers and one was supposed to be changed by the dealer to a mirror image, but not all dealers did so. Thanks for confirming this.
Dom
DMacri
United States
Posts 881
DMacri replied on Tue, Jan 22 2019 9:40 PM
That’s not for the RL-140, but for the smaller RL-60. So the answer is “it depends”. A passive radiator provides freedom from port noise, but at a higher cost than a simple port. But, the design must be based on the loading used. It’s not a simple matter to switch from ported to passive without crunching the numbers. Unless you do, you are likely to impact the quality of sound and not always for the better.
It is possible to replace the RL-60’s ABR with passive radiators, but you would need to know the mass and compliance of the ABR to match the new replacements. Or you would have to conduct trial and error analysis to find the right values.
Dom
Stereomensch
Posts 322
My Beolab pentas have a switch. So you can decide if they're used right or left.
But I never watched at the diagram, if this switch really makes a difference?
Stereomensch
Posts 322
@ Dimacri:
I thought the bassreflex solution is the just the cheap version. Usually the expensive speakers use radiators.
McRib
Posts 36
McRib replied on Wed, Jan 23 2019 8:52 AM
i have both. the pentas have a lot more power behind them but if the rls are being driven by a 6500/7000 then power is also excellent, too. both are one of only a few b&o speakers that decend to 40 hz.
McRib
Posts 36
McRib replied on Wed, Jan 23 2019 9:02 AM
i have the stands. along one of the short edges near the corner you'll see the DIN speakerlink connector. that side should be "down" so if you had speakerlink cable it would attach up into the unit. the bang olufsen name plate then reads vertically near the bottom IIRC. woofers on top. there should be an adjustment screw in the stand that lets you "dial in" the tilt from 90 deg vert to angled upwards. mine are at 90-ish.
are you using speakerlink or the original coiled speaker cable or something else?
Stereomensch
Posts 322
Oh, my rl 7000 don't have a DIN plug.
They look like this one:
http://www.baskant.dk/beovox-rl-7000-rep/
My stands don't have an adjustment screw :(
Peter Pan
Posts 2,088
Peter Pan replied on Wed, Jan 23 2019 1:05 PM
Stereomensch:
But I never watched at the diagram, if this switch really makes a difference ?
You may have misunderstood that.
DMacri
United States
Posts 881
DMacri replied on Wed, Jan 23 2019 4:35 PM
Stereomensch:
The difference is in the orientation of the tweeters. That’s their physical position rather than what channel they use from the two channel powerlink cable. It’s slightly better to have a mirror image than identical.
Dom
Stereomensch
Posts 322
That‘s the switch I was talking about.
Stereomensch
Posts 322
Stereomensch
Posts 322
Stereomensch
Posts 322
Is it necessary to change the caps of the redline speakers? How long do they last 10 years, 20 years, 30 years?
Stereomensch
Posts 322
I think the redline 7000 are a bit boring sounding. I use them with new surrounds made of foam and haven't changed any caps. But the redlines need more punch, I think.
The Pentas can realy create a wall of sound, that's great, they don't have a bass punch either.
What do you think?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 13 2020 6:13 AM
If the surrounds are new, they will be stiff - just like when they were new. Let them play and losen up a bit.
- But don't expect bass "punch" from 6,5" woofers...
Stereomensch
Posts 322
The redlines are good speakers, very balanced, neutral sounding, perfect for classical music and long listening sessions.
But they're not party speakers. The two woofers were connected directly together.
Are the 6,5 woofers as good as one 13,00 woofer?
Dillen
Posts 13,191
Dillen replied on Fri, Mar 13 2020 11:15 AM
Stereomensch:
No.
It doesn't add up like that.
It's a matter of resonance points and many other things.
(Imagine two 6,5" woofers side by side - still missing quite a bit of surface to cover one full 13" circle).
Stereomensch
Posts 322
@ Dillen:
May I ask you, do you rate the M150 (not mS150!) over the rl 7000?
What do you think?
Beofile7
Posts 150
Beofile7 replied on Sat, Mar 14 2020 7:46 AM
It's been a good few years but I had RL 140's from new with floor stands and then upgraded to Penta 2's. And it is a huge upgrade. The RL's are horrible for placement. They are so wide and in my opinion not a good looking speaker. Additionally they don't project vertically like the Pentas can. And Pentas take up minimal floor space and are just so nice to listen to. Much more detail, power and surreal softness. It's a no brainer for me.
Stereomensch
Posts 322
Has anyone ever made a comparison between the redline 7000 and the redline 140?
Am I right that the rl 7000 have the tendancy to shriek at higher volumes (using a beomaster 5000)?
AdamS
Posts 373
AdamS replied on Tue, May 12 2020 4:43 PM
Pentas every time for me. I've always thought RLs were 'orrible things and have never heard a pair I liked!
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, May 14 2020 10:08 AM
DMacri:
Peter Pan:
DMacri
Just asked my dealer, and he said some enthusiasts flipped the panel on one unit, but it was not something they were supposed to do from B&O.
What happens with the sound regarding the 4 mid-ranges ? They dont play the same frequencies, so unless the top and bottom plays the same, and the 2 middle ones do also, then you turn the mid-range "upside-down" ? I have not looked at the schematic about this yet, just a thought ?
/Weebyx
Page 1 of 2 (41 items) 1 2 Next > | RSS
