Beoplay V1-40 Hanging Ceiling Bracket
This post has 14 Replies | 2 Followers
Big_T
London, UK
Posts 14
Big_T Posted: Sat, Jan 12 2019 9:08 PM
Hi, I shall be putting up a V1-40 in a kitchen / diner and really like the idea of the hanging bracket, looks very very cool but looks very impractical
Has anyone come with a suitable solution for cabling? I will need 2 x power cables & 1 x ethernet. The IPTV device can be mounted to the rear of the TV
The only way I can see this being done, is by installing a thin as possible tube / trunking, wide enough for the 3 cables, attached to one of the hanging bracket / line thingys. Then straight up into the ceiling
Any ideas?
Cheers,
T
[BV 7-55 / BL 7-6 / BL 2 / BL 6000 / BL 8000 / BeoSystem 3 Cabinet] [BeoPlay V1-40] [BS 9000 / BL 6000] [BS Overture / BL 4000] [BeoLit 15]
Razlaw
Posts 4,345
Razlaw replied on Sat, Jan 12 2019 9:53 PM
I placed mine in a corner. Ran cables straight back from TV to corner. Then down the corner to floor level and covered with a cable cover painted to match the wall.
Big_T
London, UK
Posts 14
Big_T replied on Sun, Jan 13 2019 12:13 PM
Thanks, yeah that's an option but the plan is to hang the TV in a place not in a corner and potentially to be able to walk behind it. But sure, I could position it in a more suitable place without it being an eye sore or a pain in the a$$
Big_T
London, UK
Posts 14
Big_T replied on Sun, Jan 13 2019 2:20 PM
By the way, how easy / difficult was it to install the hanging brackets? I won't be doing it myself, I know that much!
Millemissen
Flensborg, Denmark
Posts 14,680
Did you know that there is a ceiling bracket from STBBracket.
Does not not look that ‘special’ as the original solution from B&O (which I prefer).
But you might think different - and it is probably easier to hide the cables with that.
Razlaw
Posts 4,345
Razlaw replied on Sun, Jan 13 2019 4:09 PM
Big_T:
I did not do it myself either. It did not look too difficult. I had two people do it. I don’t think a single person could do it given the weight of the TV.
Big_T
London, UK
Posts 14
Big_T replied on Sun, Jan 13 2019 4:10 PM
Yeah I've seen them. OK for a conference room but not OK for my kitchen ;-)
Big_T
London, UK
Posts 14
Big_T replied on Sun, Jan 13 2019 4:11 PM
That's good to know, cos I'm not going to use my B&O installer for this job, was going to ask my builder
Razlaw
Posts 4,345
Razlaw replied on Sun, Jan 13 2019 4:47 PM
Big_T:
That is exactly the same thing I did.....my builder installed it.
Big_T
London, UK
Posts 14
Big_T replied on Sun, Jan 13 2019 4:55 PM
Razlaw:
Big_T:
What have you got mounted to the back? Can you get universal device mounting options? All I'm having is an IPTV device, palm of your hand size
Razlaw
Posts 4,345
Razlaw replied on Sun, Jan 13 2019 5:05 PM
I do not have anything mounted to the back. The only two cables running to it are the power cord and and hdmi cable from a satellite box.
Big_T
London, UK
Posts 14
Big_T replied on Sun, Jan 13 2019 5:13 PM
Razlaw:
Ah, I suppose the way to do it, if possible, is to get a very very very very very very long remote IR extender for the device and do it that way, Would only be a thin cable and the TV power cord to hide
Razlaw
Posts 4,345
Razlaw replied on Sun, Jan 13 2019 5:46 PM
I forgot.....I do also have a very long IR cable running to the satellite box also.
Big_T
London, UK
Posts 14
Big_T replied on Wed, Jan 16 2019 5:46 PM
Are the brackets height adjustable? I've seen a library picture and the TV was very close to the floor!!!
Razlaw
Posts 4,345
Razlaw replied on Wed, Jan 16 2019 6:14 PM
I think the answer is yes.
Page 1 of 1 (15 items) | RSS
