Hi, I shall be putting up a V1-40 in a kitchen / diner and really like the idea of the hanging bracket, looks very very cool but looks very impractical
Has anyone come with a suitable solution for cabling? I will need 2 x power cables & 1 x ethernet. The IPTV device can be mounted to the rear of the TV
The only way I can see this being done, is by installing a thin as possible tube / trunking, wide enough for the 3 cables, attached to one of the hanging bracket / line thingys. Then straight up into the ceiling
Any ideas?
Cheers,
T
[BV 7-55 / BL 7-6 / BL 2 / BL 6000 / BL 8000 / BeoSystem 3 Cabinet] [BeoPlay V1-40] [BS 9000 / BL 6000] [BS Overture / BL 4000] [BeoLit 15]
Thanks, yeah that's an option but the plan is to hang the TV in a place not in a corner and potentially to be able to walk behind it. But sure, I could position it in a more suitable place without it being an eye sore or a pain in the a$$
By the way, how easy / difficult was it to install the hanging brackets? I won't be doing it myself, I know that much!
Did you know that there is a ceiling bracket from STBBracket.
Does not not look that ‘special’ as the original solution from B&O (which I prefer).
But you might think different - and it is probably easier to hide the cables with that.
Big_T:By the way, how easy / difficult was it to install the hanging brackets? I won't be doing it myself, I know that much! [BV 7-55 / BL 7-6 / BL 2 / BL 6000 / BL 8000 / BeoSystem 3 Cabinet] [BeoPlay V1-40] [BS 9000 / BL 6000] [BS Overture / BL 4000] [BeoLit 15]
Yeah I've seen them. OK for a conference room but not OK for my kitchen ;-)
That's good to know, cos I'm not going to use my B&O installer for this job, was going to ask my builder
Big_T:That's good to know, cos I'm not going to use my B&O installer for this job, was going to ask my builder [BV 7-55 / BL 7-6 / BL 2 / BL 6000 / BL 8000 / BeoSystem 3 Cabinet] [BeoPlay V1-40] [BS 9000 / BL 6000] [BS Overture / BL 4000] [BeoLit 15]
Razlaw: Big_T: That's good to know, cos I'm not going to use my B&O installer for this job, was going to ask my builder [BV 7-55 / BL 7-6 / BL 2 / BL 6000 / BL 8000 / BeoSystem 3 Cabinet] [BeoPlay V1-40] [BS 9000 / BL 6000] [BS Overture / BL 4000] [BeoLit 15] That is exactly the same thing I did.....my builder installed it.
Razlaw:I do not have anything mounted to the back. The only two cables running to it are the power cord and and hdmi cable from a satellite box.
Ah, I suppose the way to do it, if possible, is to get a very very very very very very long remote IR extender for the device and do it that way, Would only be a thin cable and the TV power cord to hide
Are the brackets height adjustable? I've seen a library picture and the TV was very close to the floor!!!
