B&O 3D Prints
This post has 49 Replies | 4 Followers
lausvi
Helsinki - Finland
Posts 689
lausvi replied on Tue, Dec 17 2019 3:43 PM
Here are some of my recent works, originals on the right:
From top to bottom: BC7000 transport screw, BM7000 cable hook, BC7000 PCB holder. Probably the same parts as used in 5500/6500, too? Haven't tested the transport mounts yet, but the other two parts did fit Ok Smile
I'll share the files when I have properly tested them in place. EDIT: ok, here are the PCB clip and the cable hook: https://www.thingiverse.com/thing:4557100 and https://www.thingiverse.com/thing:4557096. The transport screw didn't quite fit, and I haven't got time to fine-tune it to work properly.
Anyone have high-res photos and measurements of the Beogram CD transport -thingies? My CD7000 has lost them.
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Wed, Dec 18 2019 8:27 AM
I’m interested in the transport locks as well. But for the cd 6500 they seem different.
lausvi
Helsinki - Finland
Posts 689
lausvi replied on Wed, Dec 18 2019 5:36 PM
ProGram:
Yes, I believe the Beogram CD's locks are like this: https://edsgoodstuff.com/edscart/index.php?main_page=product_info&products_id=2793
adyan
Posts 1
adyan replied on Thu, Jul 30 2020 7:22 AM
Beobuddy:
Orava:
That in the middle
Like this:
Hello Beobuddy,
can you please share your .stl file?
Thanks in advance
Christian Leicht
Aarhus, Denmark
Posts 72
Guide Piece for Dust Cover for the BG4000 series:
7" Converter for BG8000 and BG8002:
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
Spassmaker
North Germany
Posts 223
Hi BeobuddyLets have a Party !!!
Is it possible for you to put you .stl File online?
Having the same problem with a cracked Spindle.
You would make quiet a lot of people lucky
Thank you very much for your advice.
Best Regards
Christian
Christian Leicht
Aarhus, Denmark
Posts 72
The Cord Holder for the BeoVox 2500 Cube:
Kind Regards,
Christian Leicht
Christian Leicht
Aarhus, Denmark
Posts 72
My take on the front grille for the BeoVox CX series:
Kind Regards,
Christian Leicht
lausvi
Helsinki - Finland
Posts 689
lausvi replied on Tue, May 18 2021 5:47 PM
I just added two file with top- and bottom panels for the LC2 dimmer: https://www.thingiverse.com/thing:4862547.
Not perfect fits and could use some more rounding on the edges but still better than missing panels :)
Pijnacker
Posts 1
Pijnacker replied on Fri, Jan 14 2022 2:49 PM
Did you ever get this part (pos 43)?
Page 2 of 2 (50 items) < Previous 1 2 | RSS
