Bad surround sound from BV10 (bitstream)
hotknife
Germany
Posts 840
hotknife Posted: Sat, Nov 24 2012 7:10 PM
Hi guys,
just upgraded to a BV10-46 and have some problems with the sound of it. I`m using the BV10 with BL9 front and BL4000 rear speaker and a TechniSat cable receiver. However the sound from the surround module of the BV10 is very bad if I´m using the bitstream format from the receiver (Bitstream = surround module of the Beovision has to do the job). If I switch to PCM format the sound improves dramatically  in all speaker modi (speaker 1, 2, 3, 5). If I switch the cable straight into the BV10 (not using the TechniSat) I receive the same bad sound.
The sound of each speaker incl. the intern center is very low, little bass. With my last BV8-40 I used the bitstream format and everything was fine. I tried several hours to solve the problem - without any success.
Thank you very much for your help in advance.
LOEWE bild 5.55 OLED + AppleTV; BS4; BL9; BL8000 MKII all black
MartinW
Posts 389
MartinW replied on Sat, Nov 24 2012 8:45 PM
I too have a BV10-46 with BeoLab 9's, BeoLab 3's at the rear, and I had a BeoLab 2 connected for a while. The sound is absolutely fantastic, so you don't need to worry about the TV not being good enough. There is always the possibility that there is a fault of course, or that perhaps it needs a software update as a number of new sound formats have come out over the past couple of years. How does it sound on other sources? Can you get your local dealer to pay a visit and check it out?
hotknife
Germany
Posts 840
hotknife replied on Sat, Nov 24 2012 8:54 PM
MartinW,
do you also use a separate tuner or do you use the inbuilt DVB-Tuner? If you use a separate one, do you have bitstream or PCM mode selected?
Thank you
mbee
Paris, France
Posts 1,842
mbee replied on Sat, Nov 24 2012 10:38 PM
The BV10 cannot decode advanced sound formats when you input in bitstream.
Just input in PCM : the result will be ABSOLUTELY EQUAL as if you had your BV10 doing the bitstream>PCM decoding. This is just mathematical (exact) conversion, it has nothing to do with high quality sound processing.
Think of the Bitstream>PCM decoding as if you where unzipping a file on a PC : the result is the same, bit for bit, with any old crappy PC or brand new shiny Mac.
hotknife
Germany
Posts 840
hotknife replied on Sat, Nov 24 2012 11:57 PM
mbee,
just found an interesting input in the archive forum
http://archivedarchivedforum2.beoworld.org/forums/p/31037/287921.aspx#287921
But mbee,
if someone does not have additional receiver, the sound from the internal surround modul is in my opinion much worser than using the PCM signal from a external receiver. Very bad solution.
Page 1 of 1 (5 items) | RSS
