Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Interesting, mine had 1.18.27862 deployed on Jan 09 2019 and does not find any new update available.
What i interesting too is that I'm set for automatic update and the update log shows that 1.18 27862 was a manual one, which is not the really the case
Razlaw:How do you access the update log?
In the product configuration main screen, select About then Diagnostics then Update logs (hopefully my french to english menu option translation works)
Razlaw:I think it added a new wireless network analysis feature under diagnostics? I do not recall seeing that feature before.
oops
Razlaw:New software for Essence also. It also seems to have added the wireless network analysis feature. That feature is not present for my Core.
Was the update for Essence 2, only? On another note, my Essence 1 has not had Tune In for a long time after coming and going as different app versions came about. Is that just mine or is Essence 1 forgotten? Still works with iPhone so doesn't matter much.
Go into the BeoApp, select the Essence, select "Product Settings", select "Configure", select "About", select "Diagnostics and Usage" and select "Wireless Network Analysis". Easy-peasy
Strange behavior for me: When I click the "Start Wireless Scans" on my Essence, it refreshes the screen, but returns no additional data. Everything works fine on my BS2.
Looks like all products are being updated, my Core just updated, BS1 and M5 were updated on the 5th.
All my products have the Wireless Network Analysis now and the Power Saving (except the A6) which is still a mystery for me, what power saving is really doing and what are the expected benefits and caveats? I had to disable it on my M3 while running the January code as it was creating the following issue: overnight, M3 was living the network, I guess after some inactivity time, and was not coming back to the network - blue LED). I have a ticket opened with B&O on this one, but I'll see if the new code has fixed it.
Also here issues with my M5 connected via WiFi. A lot of drop outs - actually you cannot Listen anymore because every 5 min it’s loosing connection.
stampfki:Also here issues with my M5 connected via WiFi. A lot of drop outs - actually you cannot Listen anymore because every 5 min it’s loosing connection.
The latest software update to products also carried with it an update to the BeoRemote One BT. The BeoRemote One can now send LIGHT and CONTROL commands via BT.
Thanks. Apparently solved it.
Stan: Go into the BeoApp, select the Essence, select "Product Settings", select "Configure", select "About", select "Diagnostics and Usage" and select "Wireless Network Analysis". Easy-peasy Strange behavior for me: When I click the "Start Wireless Scans" on my Essence, it refreshes the screen, but returns no additional data. Everything works fine on my BS2.
I have the same issue with my M3 and M5. These report the result of the wireless scan.
My both Essence mk2's don't report the results. After hitting the scan button, the screen blinks once on my iPhone, but no result is shown.
