Beoplay M5 - sw 1.19.28681.3002866
This post has 23 Replies | 3 Followers
Dyssegaard
Copenhagen, Denmark
Posts 263
Dyssegaard Posted: Sat, Feb 2 2019 1:29 PM
My M5 has been updated to v1.19.28681.3002866.
Except for some minor text updates in the configuration interface I haven’t noticed any other changes.
Have anyone noticed any functional changes?
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Feb 2 2019 1:43 PM
Interesting, mine had 1.18.27862 deployed on Jan 09 2019 and does not find any new update available.
What i interesting too is that I'm set for automatic update and the update log shows that 1.18 27862 was a manual one, which is not the really the case
Razlaw
Posts 4,345
Razlaw replied on Sat, Feb 2 2019 3:41 PM
My M5 was also recently updated to the 1.18 and shows as up to date.
How do you access the update log? I have looked for that but have nkt been able to find it.
Thanks!
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Feb 2 2019 4:03 PM
Razlaw:
In the product configuration main screen, select About then Diagnostics then Update logs (hopefully my french to english menu option translation works)
Razlaw
Posts 4,345
Razlaw replied on Sat, Feb 2 2019 8:20 PM
Thanks. I do not have a diagnostics option in the about screen. Maybe there are different versions of the app?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, Feb 2 2019 8:39 PM
You have to go to the M5 parameters and then the configuration option that will connect you to the product configuration screen (French snapshot below):
Razlaw
Posts 4,345
Razlaw replied on Sat, Feb 2 2019 8:42 PM
Thanks! Found it.
Razlaw
Posts 4,345
Razlaw replied on Tue, Feb 5 2019 2:26 AM
The new software appeared today.
Razlaw
Posts 4,345
Razlaw replied on Tue, Feb 5 2019 2:34 AM
I think it added a new wireless network analysis feature under diagnostics? I do not recall seeing that feature before.
Razlaw
Posts 4,345
Razlaw replied on Tue, Feb 5 2019 2:43 AM
New software for Essence also. It also seems to have added the wireless network analysis feature. That feature is not present for my Core.
Dyssegaard
Copenhagen, Denmark
Posts 263
Razlaw:
You are right. I tried it, and it gives a good overview of the network environment in your home.
poodleboy
Posts 303
poodleboy replied on Tue, Feb 5 2019 12:33 PM
oops
poodleboy
Posts 303
Razlaw:
Was the update for Essence 2, only? On another note, my Essence 1 has not had Tune In for a long time after coming and going as different app versions came about. Is that just mine or is Essence 1 forgotten? Still works with iPhone so doesn't matter much.
Razlaw
Posts 4,345
Razlaw replied on Tue, Feb 5 2019 12:38 PM
My Essence is a MK2, don’t know about the MK1.
jans
Belgium
Posts 394
jans replied on Tue, Feb 5 2019 6:16 PM
Razlaw:
My Essence has received the upgrade today. Where can I find this network analyses feature? I can’t find it
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Feb 5 2019 6:43 PM
Go into the BeoApp, select the Essence, select "Product Settings", select "Configure", select "About", select "Diagnostics and Usage" and select "Wireless Network Analysis".  Easy-peasy Big Smile
Strange behavior for me:  When I click the "Start Wireless Scans" on my Essence, it refreshes the screen, but returns no additional data.  Everything works fine on my BS2.
jans
Belgium
Posts 394
jans replied on Tue, Feb 5 2019 7:03 PM
Stan, I found it. Thanks! It is a usefull addition to the software!
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Feb 7 2019 1:38 PM
Looks like all products are being updated, my Core just updated, BS1 and M5 were updated on the 5th.
All my products have the Wireless Network Analysis now and the Power Saving (except the A6) which is still a mystery for me, what power saving is really doing and what are the expected benefits and caveats? I had to disable it on my M3 while running the January code as it was creating the following issue: overnight, M3 was living the network, I guess after some inactivity time, and was not coming back to the network - blue LED). I have a ticket opened with B&O on this one, but I'll see if the new code has fixed it.
Razlaw
Posts 4,345
Razlaw replied on Thu, Feb 7 2019 2:48 PM
Thanks for the info on the Core update. Will have to check mine and update it later.
stampfki
Posts 138
Also here issues with my M5 connected via WiFi. A lot of drop outs - actually you cannot Listen anymore because every 5 min it’s loosing connection.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Feb 7 2019 9:38 PM
stampfki:
I would try disabling « power saving » option which is on by default. This newly introduced unclear option seems to cause trouble.
beojeff
USA
Posts 2,012
beojeff replied on Thu, Feb 7 2019 11:41 PM
The latest software update to products also carried with it an update to the BeoRemote One BT. The BeoRemote One can now send LIGHT and CONTROL commands via BT.
stampfki
Posts 138
Thanks. Apparently solved it.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Stan:
I have the same issue with my M3 and M5. These report the result of the wireless scan.
My both Essence mk2's don't report the results. After hitting the scan button, the screen blinks once on my iPhone, but no result is shown.
Page 1 of 1 (24 items) | RSS
