Im in California and I have inherited a sound system'
It has 2 Beolab 3000
2 Beolink actives
1 Beosound 3000
1 each beomaster 4500 tape player and cd
4 beolab 4000 6638 speakers
1 Turntable
1 Beovox C75
2 BeoLab 8000 Loudspeaker
2 beolab 6000
1 Bang & Olufsen large media cabinet
3 remotes and a bunch of wiring. I dont know what to do with them and would love some advice it all looks to be 1988=1990
Some very nice items. I can only give you some very basic advice. If you post the question in the main part of the forum you will get many more answers from many more people with more expertise than me. The North American portion of the forum is not very active and the connections you are asking about would be the same anywhere. Also, some of your items may be much newer than you think such as the 4000s, 6000s, and 8000s.
What I can tell you is the following. For a simple one room system, use cables called Power Link to connect the 4000s, 6000s, or 8000s, to the Beosound 3000. The Active Kits are used to place speakers in different rooms and still use the same Beosound 3000 as a source. The Actives are connected to the 3000 with a cable called Master Link. The 4000s, 6000s, or 8000s are then connected to the Active Kit. Also, there is a round 3 inch piece with the remote sensor in that connects to the Active Kit to enable the remote to turn on the speakers and the 3000. There are also “option” settings in the 3000 and the Active Kits you program with the remote.
The Bang and Olufsen web page has a large collection of user manuals. You should be able to find the manuals for the 3000, 4000s, 6000s, 8000s and Active Kits there. The other items are older and I am not familiar with them.
Hope this helps some.
Thanks for the help im not sure I have room for all of this. It is beautiful stuff I am just not sure I need all of this.
No problem I love the system but live in a small house. It came out of a mansion in San Francisco. I am sure no cost was spared. I just don't know what to do with it
Could this be 2 systems?
ivanimal:Could this be 2 systems?
I have decided to keep the large tower speakers and the beosound 3000. it plays but the remote does not work and the volume only works with the aux cable plugged in.
Razzlaw you are a Genius! This system sounds amazing!!!!!
https://www.ebay.com/itm/382774279303
The above link is for my Ebay listing if this is not allowed please remove.
