Is it somehow possible to connect my bl 17s wirelessly to a transmitter1, but connect the BL2 trough a powerlink cable?
Best, KjetilA
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
It's for stereo. My setup is like this:
Samsung tv -> toslink -> transmitter1 -> bl17
No pre-amp and the samsung does only have toslink audio out.
I want to use a BL2 in my setup, but its not wireless. I know there is a wireless reveiver from B&O I can buy to put on the BL2 to make wireless, but I do not want to do this right now if I can avoid it.
KjetilA:It's for stereo. My setup is like this: Samsung tv -> toslink -> transmitter1 -> bl17 No pre-amp and the samsung does only have toslink audio out. I want to use a BL2 in my setup, but its not wireless. I know there is a wireless reveiver from B&O I can buy to put on the BL2 to make wireless, but I do not want to do this right now if I can avoid it.
So I only need two if I have two subs, right?
KjetilA:So I only need two if I have two subs, right?
Hi KjetilA,
You need to have just one connection for each speaker (either wired or wireless). I can help with the cables to get these speakers working, either cabled to the TV, or wireless via Transmitter 1/Receiver 1 (please see my sponsor link below for more details).
Each speaker needs its own Receiver 1, (these are already built into Beolab 17, but 2 Receivers would be ideal if you want to use Beolab 2 as a stereo subwoofer, but this can be used in mono with a single Receiver).
Please let us know your preferred setup and we can assist further.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Not sure why each speaker would need 1 additional receiver since the bl 17 already have it build in?
Yes, the Receivers are already built into Beolab 17 so you just need 2 x Receivers to use Beolab 2 in stereo, or 1 x Receiver to use Beolab 1 in mono. Sorry if my original post wasn't clear.
