Making a beo5 XML for Wyrestorm HDMI matrix from supplied IR codes
This post has 8 Replies | 3 Followers
ebnrob
UK
Posts 174
ebnrob Posted: Thu, Feb 14 2019 3:35 PM
Hi guys, I have a Wyrestorm MX-0404PP HDMI matrix which I would like my beo5 to be able to control for changing the source input. Wyrestorm have kindly sent me the IR codes in a document which I've pasted in below - are these Pronto HEX codes? Can these go straight into an XML file (using the template for starters) or do they need to be converted to a Raw format?
These are the IR commands I specifically need:
Source 1
0000 006f 0000 0022 0151 00a7 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015
0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f
0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 003f
0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 0015
0015 003f 0015 003f 0015 003f 0016 05d5
Source 2
0015 003f 0015 003f 0015 003f 0015 0015 0015 003f 0015 0015 0015 0015 0015 003f
0015 0015 0015 0015 0015 0015 0015 003f 0015 0015 0015 003f 0015 003f 0015 0015
Source 3
0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 0015 0015 003f 0015 003f
0015 0015 0015 003f 0015 0015 0015 0015 0015 003f 0015 003f 0015 0015 0015 0015
0015 003f 0015 0015 0015 003f 0016 05d5
Source 4
0015 003f 0015 003f 0015 003f 0015 0015 0015 0015 0015 0015 0015 003f 0015 0015
0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 0015 0015 003f
gerard
Luxembourg
Posts 331
gerard replied on Sun, Mar 10 2019 12:54 AM
I'm not an expert at this, but it looks like the pronto codes described by jacob rungwald here:
http://rungwald.dk/intro/home/the-tpf-file/index.html
jacob wrote an iPad App called "Beo5/6 third party configurator" to convert pronto codes to xml for the Beo5/6 programming tool.
Video here:
http://rungwald.dk/intro/home/theapp/video-example.html
Maybee this could help
gerard
ebnrob
UK
Posts 174
ebnrob replied on Tue, Mar 19 2019 7:24 PM
Thanks Gerard, I will take a look at the ipad app for this purpose.
Rob.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Rob,
I can confirm that these are Pronto codes which convert to 32 bit NEC IR codes as below:-
Regards Keith....
Keith Saunders
Posts 5,495
Attached is an XML file made from your Pronto codes for you to test in your Beo5
Regards Keith....
ebnrob
UK
Posts 174
ebnrob replied on Tue, Mar 19 2019 9:04 PM
Wow thank you Keith that's brilliant! I will give it a go. Much appreciated.
Rob.
gerard
Luxembourg
Posts 331
gerard replied on Tue, Mar 19 2019 10:31 PM
Here is a link for the App:
Tutorial: http://youtu.be/isMyKMlmjso
Keith Saunders
Posts 5,495
Gerard,
Your link is for an app built by a Beoworld member Jacob Rungwald for use on an iPad.
The screen shots in this thread are of my converter which I built about 10-12 years ago and is Windows based only and never distributed to anyone. I used it to convert PUC, Lintronic and Pronto files to Beo5/6 compatible XML files for Beoworld members at the early stage of the Beo5.
I used it to convert the Wyrestorm HDMI matrix pronto codes into a usable XML file for the Beo5/6
Regards Keith....
gerard
Luxembourg
Posts 331
gerard replied on Fri, Mar 22 2019 1:21 AM
Hi Keith,
The link I'm talking about, was a link to a converter tool, I think from Lintronic, it was on some sort of wiki page for the Beo5/6, explaining jow to get pronto vodes using an HP iPaq.
I can't find this wiki anymore
Page 1 of 1 (9 items) | RSS
