Hi guys, I have a Wyrestorm MX-0404PP HDMI matrix which I would like my beo5 to be able to control for changing the source input. Wyrestorm have kindly sent me the IR codes in a document which I've pasted in below - are these Pronto HEX codes? Can these go straight into an XML file (using the template for starters) or do they need to be converted to a Raw format?
These are the IR commands I specifically need:
Source 1
0000 006f 0000 0022 0151 00a7 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015
0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f
0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 003f
0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003f 0015 0015
0015 003f 0015 003f 0015 003f 0016 05d5
Source 2
0015 003f 0015 003f 0015 003f 0015 0015 0015 003f 0015 0015 0015 0015 0015 003f
0015 0015 0015 0015 0015 0015 0015 003f 0015 0015 0015 003f 0015 003f 0015 0015
Source 3
0015 003f 0015 003f 0015 003f 0015 003f 0015 0015 0015 0015 0015 003f 0015 003f
0015 0015 0015 003f 0015 0015 0015 0015 0015 003f 0015 003f 0015 0015 0015 0015
0015 003f 0015 0015 0015 003f 0016 05d5
Source 4
0015 003f 0015 003f 0015 003f 0015 0015 0015 0015 0015 0015 0015 003f 0015 0015
0015 0015 0015 0015 0015 0015 0015 003f 0015 003f 0015 003f 0015 0015 0015 003f
Thanks Gerard, I will take a look at the ipad app for this purpose.
Rob.
Rob,
I can confirm that these are Pronto codes which convert to 32 bit NEC IR codes as below:-
Regards Keith....
Attached is an XML file made from your Pronto codes for you to test in your Beo5
Wow thank you Keith that's brilliant! I will give it a go. Much appreciated.
Here is a link for the App:
Tutorial: http://youtu.be/isMyKMlmjso
Gerard,
Your link is for an app built by a Beoworld member Jacob Rungwald for use on an iPad.
The screen shots in this thread are of my converter which I built about 10-12 years ago and is Windows based only and never distributed to anyone. I used it to convert PUC, Lintronic and Pronto files to Beo5/6 compatible XML files for Beoworld members at the early stage of the Beo5.
I used it to convert the Wyrestorm HDMI matrix pronto codes into a usable XML file for the Beo5/6
Hi Keith,
The link I'm talking about, was a link to a converter tool, I think from Lintronic, it was on some sort of wiki page for the Beo5/6, explaining jow to get pronto vodes using an HP iPaq.
I can't find this wiki anymore
