Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
With you using this as the main screen, I think you’ll be OK.
The protocol looks the same, and the serial port speed is the same. On/off commands and prefixes are the same (PON/POF) The only difference is the plug on the projector.
although not having tried it, so caveat emptor! Note that you need to tell the Beosystem 3 that you are using a B&O monitor so it will send commands through the serial port. Choose a relatively early display (with the correct resolution) to minimise all the extra commands the Beosystem 3 will send.
I’ve never used a projector, but if you choose one that can be switched on/off with HDMI-CEC, then you can do this with a serial cable and a raspberry PI. that’s how I drive a couple of Beosystem 3s with a LG and Samsung (respectively) monitor attached
If you have the PUC, set it for plug with no modulation
frog:If you have the PUC, set it for plug with no modulation
That’s not a good sign; the stereo cable should work just as well. Maybe worth trying with modulation (although I’ve never seen that!).
as for on/off- does the remote have separate on and off buttons?
