BeoSystem 3 and Panasonic projector
This post has 18 Replies | 0 Followers
DMacri
United States
Posts 881
DMacri Posted: Fri, Mar 1 2019 1:04 AM
Does anyone know if the RS-232 control connection for the monitor port connected with display one can operate a Panasonic PT-AX100U lcd projector? I’m only looking for on and off control.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
DMacri
United States
Posts 881
DMacri replied on Sat, Mar 2 2019 12:04 PM
Or perhaps asked another way - does anyone know if the RS-232 connection is generic enough that another tv/monitor/projector will accept the issued commands from the BeoSystem 3? If so, it could give my theater system an easier integration by keeping the IR signals in the equipment closet and route a comm cable to the ceiling projector. I would appreciate anyone’s experience here.
Dom
DMacri
United States
Posts 881
DMacri replied on Tue, Mar 12 2019 11:21 PM
I found an outfit that will custom order a one-off cable for me for about $65. Before I waste my time (I may have already wasted my money), does anyone know if this will work?
Dom
frog
Camberley UK
Posts 624
frog replied on Sun, Mar 17 2019 8:37 PM
With you using this as the main screen, I think you’ll be OK.
The protocol looks the same, and the serial port speed is the same. On/off commands and prefixes are the same (PON/POF) The only difference is the plug on the projector.
although not having tried it, so caveat emptor! Note that you need to tell the Beosystem 3 that you are using a B&O monitor so it will send commands through the serial port. Choose a relatively early display (with the correct resolution) to minimise all the extra commands the Beosystem 3 will send.
frog
Camberley UK
Posts 624
frog replied on Mon, Mar 18 2019 12:29 AM
I’ve never used a projector, but if you choose one that can be switched on/off with HDMI-CEC, then you can do this with a serial cable and a raspberry PI. that’s how I drive a couple of Beosystem 3s with a LG and Samsung (respectively) monitor attached
DMacri
United States
Posts 881
DMacri replied on Mon, Mar 18 2019 9:38 AM
I’m hoping the custom cable I ordered will be able to control the projector directly. I’ll see what happens next weekend, after it comes in. I don’t think the projector has HDMI-CEC control.
Dom
DMacri
United States
Posts 881
DMacri replied on Mon, Mar 18 2019 10:14 AM
So here’s my stupid question of the day - can I just plug a mono cable between the BeoSystem 3 control output and the Oppo Blu-ray player IR input? If so, do I set it for IR or Plug?
Dom
frog
Camberley UK
Posts 624
frog replied on Mon, Mar 18 2019 10:20 AM
If you have the PUC, set it for plug with no modulation
DMacri
United States
Posts 881
DMacri replied on Mon, Mar 18 2019 10:24 AM
frog:
Thanks, that’s great information and will lead to a much cleaner installation, with less dangling wires.Big Smile
Dom
DMacri
United States
Posts 881
DMacri replied on Tue, Mar 19 2019 9:31 AM
I tried connecting a stereo cable instead of a mono cable, changed to “plug without modulation” and it did not provide control. I’ll buy a mono cable soon and try again.
I’ll note the PUC, when used with IR, can provide control to a point. It will turn the Oppo off, skip tracks, pause and play, but will not turn it on. Any ideas?
Dom
frog
Camberley UK
Posts 624
frog replied on Tue, Mar 19 2019 11:25 AM
That’s not a good sign; the stereo cable should work just as well. Maybe worth trying with modulation (although I’ve never seen that!).
as for on/off- does the remote have separate on and off buttons?
DMacri
United States
Posts 881
DMacri replied on Tue, Mar 19 2019 2:15 PM
I’ll try again later with the stereo cable with and without modulation
Dom
DMacri
United States
Posts 881
DMacri replied on Tue, Mar 19 2019 7:47 PM
I tried it again and set it to use modulation and now it works perfectly! Lets have a Party !!!Thanks for your help.
Now I need to hook up my projector to my other BeoSystem 3 on the weekend.
Dom
DMacri
United States
Posts 881
DMacri replied on Mon, Mar 25 2019 7:02 PM
I changed the monitor to one of the later versions that supports HD and I was able to set the resolution to 720P for my projector. Now the projector can turn on and off from my BeoSystem 3!Lets have a Party !!!
I do note the video seems to have a little vibration to it - as if it’s shifting one pixel up and down rapidly. Does that make sense? Is there a way to correct this behavior?
I tried multiple B&O model settings, and some must have gone to a resolution my projector does not support. I had to reset several times to get it into safe mode. Mostly ok now.
Dom
DMacri
United States
Posts 881
DMacri replied on Mon, Mar 25 2019 11:14 PM
I am also able to control my Sony Universal Disk player with the direct plug and PUC. Much cleaner than the IR blinker.
Dom
DMacri
United States
Posts 881
DMacri replied on Tue, Apr 2 2019 5:40 PM
I can control the Sony UHD Blu-ray by plug too, but with modulation turned off.
Dom
DMacri
United States
Posts 881
DMacri replied on Tue, Apr 2 2019 5:42 PM
The problems I was having with the projector turned out to be the incompatibility of the default resolution from the B&O monitor settings. Once I found a compatible output, I was fine.
Dom
DMacri
United States
Posts 881
DMacri replied on Tue, Apr 2 2019 5:45 PM
So now my BeoSystem 3 will lock up and not respond to remote control after a few minutes of use. If I power cycle, I get control back for a while. Had anyone had this problem? Any suggestions before I exercise my warranty?
Dom
DMacri
United States
Posts 881
DMacri replied on Sun, Apr 21 2019 10:48 PM
I need to adjust the timing between the startup of the monitor (projector in my case) and the electronic curtains opening. Does anyone know how that is done? Is there a B&O monitor setting that had a longer startup time than the others, such as the BV4-50 D9 HD that I am currently using?
Dom
Page 1 of 1 (19 items) | RSS
