Beolink Active PC input works with Beolink 1000 but not with Beo4
This post has 6 Replies | 3 Followers
swo
Posts 15
swo Posted: Wed, Mar 6 2019 7:02 PM
Hi
I use a Beolink Active 1636 SW 1.1. The PC input works perfect with Beolink 1000 Shift + Store. But when I use a Beo4 it doesn't work, not with PC neither L_PC.
Anny idea?
Thanks Wolfgang
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Mar 6 2019 9:54 PM
Is the active also connected by Masterlink to an Audiomaster?  Is there any chance that the (more powerful) Beo4 could be transmitting to an audiomaster at the same time?
I assume that you have used a camera to check that the Beo4 is actually transmitting when PC is selected and GO pressed?
swo
Posts 15
swo replied on Fri, Mar 8 2019 10:26 PM
Hi
yes it is connected to an Beomaster 4500.
No the Beomaster is in an other Room
yes I used the crll phone to test the Beo4. I also tryed an other Beo4.
swo
Posts 15
Hi
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Mar 8 2019 10:50 PM
Maybe try resetting the option settings of the Beolink Active.  Try 0, 4, 5 and 6 with each remote in turn.
Make sure that whole system is in stand-by first, and then use the BL1000 to set the option by pressing LINK (Option Number) then STORE for each.  Try each remote after each setting (but obviously neither should work for option 0)
The correct option for your set-up would probably be 6.
swo
Posts 15
swo replied on Sat, Mar 9 2019 12:09 PM
Thank you very much
set the Beolink Active to Option L-Opt 6 solve the issue
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Mar 9 2019 12:50 PM
Great news - thanks for letting us know that it worked! Smile
Page 1 of 1 (7 items) | RSS
