HiI use a Beolink Active 1636 SW 1.1. The PC input works perfect with Beolink 1000 Shift + Store. But when I use a Beo4 it doesn't work, not with PC neither L_PC.Anny idea?Thanks Wolfgang
Is the active also connected by Masterlink to an Audiomaster? Is there any chance that the (more powerful) Beo4 could be transmitting to an audiomaster at the same time?
I assume that you have used a camera to check that the Beo4 is actually transmitting when PC is selected and GO pressed?
Hi
yes it is connected to an Beomaster 4500.
No the Beomaster is in an other Room
yes I used the crll phone to test the Beo4. I also tryed an other Beo4.
Maybe try resetting the option settings of the Beolink Active. Try 0, 4, 5 and 6 with each remote in turn.
Make sure that whole system is in stand-by first, and then use the BL1000 to set the option by pressing LINK (Option Number) then STORE for each. Try each remote after each setting (but obviously neither should work for option 0)
The correct option for your set-up would probably be 6.
Thank you very much
set the Beolink Active to Option L-Opt 6 solve the issue
Great news - thanks for letting us know that it worked!
