BM 6500 mute relay & other components
Beomatt
Posts 6
Beomatt Posted: Fri, Mar 8 2019 8:00 AM
hi, can anyone provide a link or specification for a replacement muting relay for my BM6500 please? Also any other components that may help get stereo back as it’s on one channel only on speaker output 1? Many thanks in advance BeoMatt
solderon29
U.K.West Midlands
Posts 764
I've been using a Finder relay,original makers ref No:4052-9006.
If you search for this number,you should be offered suppliers near to you.
You'll need to remove two pins to allow fitting to the pcb.
Regards,
Nick
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 8 2019 11:54 AM
I can supply the relay.
PM or email me.
Beomatt
Posts 6
Beomatt replied on Thu, Mar 14 2019 6:48 AM
I have sourced a relay many thanks, can anyone confirm how you remove the mute board so that I can solder new relay in place?
Beomatt
Posts 6
Beomatt replied on Thu, Mar 14 2019 6:50 AM
I meant small PCB relay attaches to? Are the support posts soldered on PCB? I
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Mar 14 2019 7:38 AM
Beomatt:
Yes, and they actually are used as connections, so make sure they are soldered correctly afterwards :)
/Weebyx
Page 1 of 1 (6 items) | RSS
