hi, can anyone provide a link or specification for a replacement muting relay for my BM6500 please? Also any other components that may help get stereo back as it’s on one channel only on speaker output 1? Many thanks in advance BeoMatt
I've been using a Finder relay,original makers ref No:4052-9006.
If you search for this number,you should be offered suppliers near to you.
You'll need to remove two pins to allow fitting to the pcb.
Regards,
Nick
I can supply the relay.PM or email me.
I have sourced a relay many thanks, can anyone confirm how you remove the mute board so that I can solder new relay in place?
I meant small PCB relay attaches to? Are the support posts soldered on PCB? I
Beomatt: I meant small PCB relay attaches to? Are the support posts soldered on PCB? I
Yes, and they actually are used as connections, so make sure they are soldered correctly afterwards :)
/Weebyx
