best B&O Dolby 5.1 for a projector- Beosystem 3 or Beovision 7
This post has 7 Replies | 2 Followers
JulianJ
Posts 66
JulianJ Posted: Tue, Nov 27 2012 4:12 PM
Good Afternoon,
I am a long-time B&O enthusiast looking to expand the sound on my existing Projector setup.
My Optoma projector is connected to a PS3 via an HDMI cable.
For the audio the PS3 is connected via component cables to a B&O Overture driving a pair of Beolab 1 speakers, giving a very impressive stereo soundtrack.
I would like to upgrade the 'stereo' to Dolby 5.1 by adding three more B&O speakers & a suitable 5.1 'driver'. My two favourite options are;
1. Purchase a used Beosystem 2 to drive the speakers - but I understand from elsewhere on this forum it my require some modification to enable it to work independently ie without a screen?
2. Purchase an early Beovision 7-32 & mount it behind the projector screen - I understand these sets have a 'projector' socket especially for this purpose?
Looking at used prices, both options would cost around £400, plus of course the cost of the extra speakers & cabling etc.
I would be grateful for any advice or opinions!
Kind Regards
Julian
Borjal84
Posts 24
Borjal84 replied on Tue, Nov 27 2012 6:17 PM
One good solution could be this:
http://shop.emotiva.com/collections/processors/products/umc1
JulianJ
Posts 66
JulianJ replied on Tue, Nov 27 2012 8:48 PM
Thank you Borjal84,
But that item is not available anywhere on the internet!
Kind Regards
Julian
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Nov 27 2012 10:15 PM
Any avr with pre outs??
Ralf
miniac
Posts 9
miniac replied on Tue, Nov 27 2012 10:15 PM
if you decide that you only go for bang&olufsen speakers in your new setup I can sell you (for £200 plus packaging) a rarely used detoma X501 dolby surround decoder especialy made for B&O speakers and for the Ouverture, as it has the same size and looks perfect situated under the Ouverture.
kind regards
Flo
JulianJ
Posts 66
JulianJ replied on Wed, Nov 28 2012 10:07 AM
Thank you all for your suggestions,
Am I correct in thinking that by using a non-B&O AVR the B&O speakers will automatically switch off during long silent periods during movies?
Also, which outputs from the Overture would feed the AVR?  The Overture only has two active 'Speaker out' sockets. Can these be used to feed the AVR?
Kind Regards
Julian
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Nov 28 2012 10:55 AM
Take a look at this thread
Best regards
Ralf
JulianJ
Posts 66
JulianJ replied on Wed, Nov 28 2012 1:15 PM
Thank you all again for your input.
if I decide to opt for a non-B&O amp, presumably I will have to have a separate control for the volume?
What would be the best solution if I were to insist on using only Bang & Olufsen products?
Kind regards
Julian
Page 1 of 1 (8 items) | RSS
