Beolab Penta woofer buzzing
This post has 5 Replies | 0 Followers
DMacri
United States
Posts 881
DMacri Posted: Sun, Mar 24 2019 11:42 AM
I have one woofer in one of my MkII Pentas that has an occasional buzz. Only one woofer does this, but if I push very lightly on the cone I can make it subside for some time. It will come back after some low bass notes. I’m assuming the voice coil is coming off the former and the woofer is in need of replacement. The buzz is in line with the music and follows deep tones. Am I right, or are there other options?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Mon, Mar 25 2019 11:20 AM
You can try as follows: unscrew the bass unit, turn 180 degree around (from 6 to 12 o’clock) and screw it back it’s place. I’ve experienced that the cones are hanging somehow over the years. So I suggest to do this with al bass drivers.
DMacri
United States
Posts 881
DMacri replied on Mon, Mar 25 2019 11:47 AM
I just tried that and I'm not sure it's going to work for me. There seems to be a good amount of resistance to cone movement. If I press on just one side of the dust cap at a time, I can just find a pressure point that makes less of a scraping sound. I think replacement is the only choice now, unless someone can suggest an outfit that can repair it, or can provide me with some DIY instructions. Since I'm counting on replacement, I guess there is no harm in trying a repair, but I don't want to go into it blind.
Dom
ProGram
Posts 383
ProGram replied on Mon, Mar 25 2019 12:46 PM
DMacri:
I agree because it seems to be a deformed coil then
DMacri
United States
Posts 881
DMacri replied on Tue, Apr 2 2019 7:11 PM
I plan to buy one from the repair center this week. The voice coil is shot.
Dom
DMacri
United States
Posts 881
DMacri replied on Sat, Apr 6 2019 5:37 PM
My wife was nice enough to pick up a new woofer for me yesterday and I installed it this morning. All good.
Dom
Page 1 of 1 (6 items) | RSS
