Happy sunday to all of you.
I have a small! problem with my Beolab 5's. They don't turn on!.
Beolab 5's are connected to Beovision 10. I've check the source with the other speakers; cables and Beovision 10 are ok.
The speakers don't give any failure. The lights are red as they are on standy by.
When I press the button on top calibration starts and ends normally.
I connected Beolab's 5 to Beosystem 4500 and result is the same they don't turn on.
Unplugged and checked again. Nothing changed.
What can be the problem? Any idea?
Thank you for your help in advance.
Bulent
Maybe someone changed the Option L and now they will turno on only via infrared?
I've tried different Link Options. Option 1 turns the speakers on but still no sound.
Could you (Thread starter) please contact me via the Beoworld Contact Us HERE
Keith Saunders (Beoworld System Administrator and Moderator)
Regards Keith....
Rothna: What can be the problem? Any idea? Thank you for your help in advance. Bulent
Do you use the PL cables, that come with the BL5’s?
They have to be fully wired/MK2 cables - the thick ones.
Look here for an explanation of the different types of PL cables:
http://www.soundsheavenly.com/faq/guide-various-types-powerlink-cable-bang-olufsen-use/
Thank you for the messages. First of all I can't understan why the system change my nickname to Rothna! Anyway, this is not important.
I'm not new in B&O world neither Beolab 5's in my house. I bought them new and they worked until last week with the same cable. So the cables are fully wired. I also have the original BL5 cables. They didn't bring anything either.
I belive BL5's were working until the replacement Beo 1 remote arrived. This was setted up for Eclipse. I've change the setup to Beovision and done deal. But it can be a coincidence...
B&O customer support thinks that is a software problem! Suggest me to call a technician.
Beovision Avant 55 / BV 11-40 / BV7-40 / Beovision Avant / Beosound 9000 / Beosound 5 Encore / Beosystem 4500 / Beosystem 6500 / Beocenter 9000 / Beolab 5000 / Beolab 18 / Beolab 19 / Beolab 11 / Beolab 17 / 3 sets of Beolab 4000 / Beovox Red Line 60.2
If the BR1 is a Bluetooth, and the Eclipse doesn't have the BL5's set up properly in the menu, this could be the issue?
