Beolab 50
This post has 167 Replies | 2 Followers
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Apr 19 2019 9:29 PM
From personally owning them, i love my 18’s and are probably my favourite speakers to own but even with a bl19 they have noting on the 50’s in terms of sound. Even if you had two 19’s with it it still not there, not even close. It’s a great setup, no doubt, but it’s on the same level.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Esax
Posts 323
Esax replied on Fri, Apr 19 2019 9:30 PM
Razlaw:
No. My question has to do with the imaging attainable given the technology that only the 50s and 90s have. I will rephrase it this way, to those who have 50s, is figure 4.4 on page 12 of the Beolab 50 Technical Sound Guide and accurate depiction of what will be heard when listening to the 50s.
Thank you in advance for any opinions on it.
I got the all but the depth. Probebly because I got the 7-55 on floorstand with beolab 10. And all in the wrong lengthwise of the room.
A good place to learn more of imaging and hifidelity is ”ask paul” on youtube from ps audio.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Esax
Posts 323
Esax replied on Fri, Apr 19 2019 9:39 PM
Razlaw:
I got all but the depth. Probably due to the fact that my bv 7-55 on the floor stand whit bl 10 in between. And that everything is on the long side of the room. A great place to learn more about rooms and location is by Paul Mcgowan from ps audio, ask paul on youtube.
Razlaw
Posts 4,345
Razlaw replied on Fri, Apr 19 2019 9:58 PM
Deleted
Razlaw
Posts 4,345
Razlaw replied on Fri, Apr 19 2019 10:27 PM
Esax:
I got all but the depth. Probably due to the fact that my bv 7-55 on the floor stand whit bl 10 in between. And that everything is on the long side of the room. A great place to learn more about rooms and location is by Paul Mcgowan from ps audio, ask paul on youtube. Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Thanks! Much appreciated!
Razlaw
Posts 4,345
Razlaw replied on Fri, Apr 19 2019 10:35 PM
Do you have any pictures of the 50s with your 7? Curious to see how they look together.
PaulGiles
Posts 218
PaulGiles replied on Sat, Apr 20 2019 9:36 AM
Razlaw:
Why would I want to downgrade from 20s to 18s?
No, in addition to the 20’s, 18’s as rears.
As mentioned before, the 7 is now very old and that would be the best upgrade first.
All depends on what you are using it for percentage music/tv.
Only heard the 50s and 90s with the eclipse so cannot really comment on the 7/50 mix.
I’m sure you won’t be disappointed with any set up with the 50’s.
Esax
Posts 323
Esax replied on Sat, Apr 20 2019 9:42 AM
Yeah I know it don’t match.
Esax
Posts 323
Esax replied on Sat, Apr 20 2019 10:01 AM
PaulGiles:
Beovision 7 may be old. But that doesn't mean they're not good. I listen to music both on youtube and apple tv through the tv. But also streamed via airport express direct to the beolab 50, apple music and flac. there is no big difference in quality. May be the difference in the dacs.
One big advantage is that you can set up beolab 50 to start with low latency and wide when watching TV. And high latency and narrow when streaming. If you have set everything correctly, it switches automatically.
Razlaw
Posts 4,345
Razlaw replied on Sat, Apr 20 2019 10:34 AM
PaulGiles:
I have 12-3s as rears. I agree the Eclipse would be a great upgrade and logically the one I should do.
Razlaw
Posts 4,345
Razlaw replied on Sat, Apr 20 2019 10:35 AM
Esax:
Yeah I know it don’t match. Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Beautiful! And thank you so much! It really helps me visualize how the 50s would look with my 7-55.
Razlaw
Posts 4,345
Razlaw replied on Sat, Apr 20 2019 10:38 AM
Esax:
One big advantage is that you can set up beolab 50 to start with low latency and wide when watching TV. And high latency and narrow when streaming. If you have set everything correctly, it switches automatically. Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
I did not know that the automatic switching was possible with the 7. I am very glad to hear that it is. Thank you for all of the information. It is very helpful to me in making my decision.
Esax
Posts 323
Esax replied on Sat, Apr 20 2019 10:58 AM
Razlaw:
It is the b&o app that makes it possible.
Razlaw
Posts 4,345
Razlaw replied on Sat, Apr 20 2019 1:56 PM
Were you happy with the set up process using the microphone?
Also, one of the reasons I have been hesitant to replace my BV 7 is that it is connected by Masterlink to two other rooms and a Beosound 3000 and Beosound 5. I have not wanted to lose that connectivity, which I would with an Eclipse. However, it just occurred to me this morning, would it be possible to connect the 50s to an Eclipse with PowerLink, a Core by optical, and then also a BeoLink Active through one of the other inputs? (Perhaps I could do the same with the 20s as they have three inputs)
PaulGiles
Posts 218
PaulGiles replied on Sat, Apr 20 2019 3:59 PM
Never said they were not good, superb looking sets and great sound when used with the 7.X range.
Esax
Posts 323
Esax replied on Sat, Apr 20 2019 5:00 PM
I’ve tried the mic in my previously home and it did make an improvment. The sound is clearer and less boomy. The active room correction works well. But they are really good from scratch. I’m told that b&o did a hole lot of mesurments in different rooms and the preset is a mix of thoose.
Esax
Posts 323
Esax replied on Sun, Apr 21 2019 11:07 AM
Must ad that the beolab 50 is perfekt in any way. And more base than beolab 9 with 2x beolab 2. You can feel the base from the beolab 50 at low levels. And very plesent treble and not tirering to listening to. Even at very loud levels. Hard to know how loud you play until your neighbours knocking on the door.
Razlaw
Posts 4,345
Razlaw replied on Sun, Apr 21 2019 11:53 AM
Esax:
Must ad that the beolab 50 is perfekt in any way. And more base than beolab 9 with 2x beolab 2. You can feel the base from the beolab 50 at low levels. And very plesent treble and not tirering to listening to. Even at very loud levels. Hard to know how loud you play until your neighbours knocking on the door. Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Thank you again for all of the information. I have both BL 9s and 20s. Have been very happy with both. But I know the 50s would take it to an entirely new level. Still debating a 1000 mile flight to listen. Unfortunately my nearest dealer that is only a three hour drive away does not currently have 50s.
Razlaw
Posts 4,345
Razlaw replied on Wed, Apr 24 2019 12:08 AM
Have a demo scheduled for the middle of next month 😀. Then I can decide. Again, thank you for all of the information everyone has provided.
Esax
Posts 323
Esax replied on Sat, Apr 27 2019 12:52 PM
Your wallet will feel easier.
Razlaw
Posts 4,345
Razlaw replied on Sat, Apr 27 2019 3:43 PM
Yes. Will make the decision much easier and make for a much better decision.
Mr 10Percent
So West, Its Now East
Posts 591
Some free advice - not that I think you need it.
Check with your Dealer what the source is going to be. Personally, unless it was for movie going, I’d ensure there’s a decent audio source somewhere handy. Listening to Spotify/Dezer etc via a BV Powerlink connection.....well think what you want...it’s ones and zeros and anything more than 320k can’t be distinguished right??
Razlaw
Posts 4,345
Razlaw replied on Sat, Apr 27 2019 5:42 PM
Demo will be using a Core, possibly a video source, and some high resolution files on a USB. I am thinking that should give me a pretty good idea of how they sound? (I will take and welcome any and all advice😊)
Razlaw
Posts 4,345
Razlaw replied on Thu, May 16 2019 2:08 AM
Had demo today.....very impressed.....now decision time.
Sweden
Posts 357
Silver Member
Martin replied on Thu, May 16 2019 4:20 PM
Hi, I have just pulled rhe trigger for Beolab 50. Delivery 3rd of June. Will be nice to upgrade from Beolab 5.
Best Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Duels
England
Posts 2,553
Duels replied on Thu, May 16 2019 4:33 PM
Martin:
Excellent stuff. Can we have some pictures in due course please?
Duels
England
Posts 2,553
Razlaw:
Just do it. You won’t regret it.
Mikipidia
Posts 2,169
Mikipidia replied on Thu, May 16 2019 9:19 PM
Sorry for the delay martin but i figured out my issues now too and should be fixed soon as in tuesday. Last of all the issues did turn out to be in the wiring and partially the tv. So you have my blessingStick out tongue
Millemissen
Flensborg, Denmark
Posts 14,680
Happy fifty-ing 😀
Just be sure, that they are updated with the latest sw.....both of them, the same!
seethroughyou
UK
Posts 999
Martin:
Oh my gosh, that feeling is so unforgettable. I remember the trepidation ordering my first Beolabs in 2000. I was so nervous and thought “what the hell, life’s short, do it!!!” It’s second only to the first few seconds when you power them up and that gorgeous music bathes the room. Bliss!
We want to see photos ASAP!
Excited for you.
Good move, the BL50 are definitely a massive step-up from BL5.
You will not regret it one bit.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Razlaw
Posts 4,345
Razlaw replied on Fri, May 17 2019 1:52 AM
Has anybody seen the metal grill on the piano black edition and have an opinion how it looks in person? How shiny is it in person? Am thinking of ordering silver 50s with black cloth on the back and metal grill on the front.....am trying to visualize how the silver of the 50 and the silver of the grill would look together.
Thanks!
seethroughyou
UK
Posts 999
Only seen pictures of the piano ball and does remind me of the Mercedes grille. They are rare and I’ve only ever seen the standard aluminium and black cloth version at dealers. Looks flash now but probably will be a bit dated in a few years. I’m not sure if I like it or not. Depends a lot on your decor I suppose and personal taste. One man’s meat is another’s poison an all that....Would be worth hunting a pair down in piano black.
Sweden
Posts 357
Silver Member
Martin replied on Fri, May 17 2019 8:44 AM
Hi guys,
I will post photos as soon as I get the lab50
Best Regards
Barry Santini
New York
Posts 543
Black =dust
Mikipidia
Posts 2,169
Mikipidia replied on Fri, May 17 2019 12:12 PM
I’ll take a picture for you next tuesday when iam at my dealer again. He has them all it seems. So i’ll ask him if we can play around with the coversSmile
Razlaw
Posts 4,345
Razlaw replied on Fri, May 17 2019 1:52 PM
Mikipidia:
I’ll take a picture for you next tuesday when iam at my dealer again. He has them all it seems. So i’ll ask him if we can play around with the covers New: Beolab 50's, Beolab 18's, Beovision eclipse, Beosound 9000 mk3, Beosound 1 Bronze edition, Beoplay M3.
Mikipedi4 on YouTube
https://www.youtube.com/c/mikipedi4
Old: Beolab 1's, beolab 2, beovision 10-46, overture 2300, beolab 8000's, beolab 4000's, beovision avant 32" etc. etc.
Thanks!
MaxH
Posts 126
MaxH replied on Fri, May 17 2019 2:34 PM
The metal grill version is a touch on the aggressive side for my taste ( and that is also influenced by the female in my life) but the silver is to die for.
Obviously, it depends on taste and furnishing but here are mine and I an going the add the smoked oak to the front of the TV next week.
The sound is fabulous :-)
Razlaw
Posts 4,345
Razlaw replied on Fri, May 17 2019 2:50 PM
I am just about ready to say yes and order a pair. I am concerned that the wall they would be on might be too short. I have a BV7-55 and to the right of it a Beosystem 1 cabinet with BlueRay, Sat box etc in it. There is only 25 inches between the tv and the cabinet. With the Beolab 50s being 18 inches wide, that makes for a very tight fit.
Michael
Sweden
Posts 2,578
Michael replied on Fri, May 17 2019 3:19 PM
I would consider waiting a while for any new color combos that might come this year. I find the regular one a bit much and the one with the black star net a bit cooler. An even more subtle or cooler color combo would fit even better. So many different materials on the Bl 50 standard. But I guess one gets used to it.
MaxH
Posts 126
Page 2 of 5 (168 items) < Previous 1 2 3 4 5 Next > | RSS
