Beo Com 6000
This post has 4 Replies | 2 Followers
gdoyle61
Posts 6
gdoyle61 Posted: Fri, Nov 30 2012 4:50 AM
I bought a second-hand Beo Com 6000, which works great but it won't let me delete the old phonebook. I have followed the manual but still can't delete. Can anybody help me with advice?
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, Nov 30 2012 10:36 PM
The handset will have been registered to the same base twice or another base. You can go into the set up menu and reset the base and then the handset to factory status. The register the handset to the base as new. That will wipe the phonebook.
Opman
gdoyle61
Posts 6
Thanks Opman, But i can't even get in to the menu! Button 7, I have tried everything in the manual but the whole thing seems to be 'locked'?
kokomo
Spain
Posts 206
kokomo replied on Sat, Dec 1 2012 10:51 AM
gdoyle61:
Are you pressing the button with the black dot first then button 7?
gdoyle61
Posts 6
Thanks mate, perfect advice and solved my problems. Thank you again for you help.
Gary.
Page 1 of 1 (5 items) | RSS
