I bought a second-hand Beo Com 6000, which works great but it won't let me delete the old phonebook. I have followed the manual but still can't delete. Can anybody help me with advice?
The handset will have been registered to the same base twice or another base. You can go into the set up menu and reset the base and then the handset to factory status. The register the handset to the base as new. That will wipe the phonebook.
Opman
Thanks Opman, But i can't even get in to the menu! Button 7, I have tried everything in the manual but the whole thing seems to be 'locked'?
gdoyle61: Thanks Opman, But i can't even get in to the menu! Button 7, I have tried everything in the manual but the whole thing seems to be 'locked'?
Are you pressing the button with the black dot first then button 7?
Thanks mate, perfect advice and solved my problems. Thank you again for you help.
Gary.
