You can easily assign a specific Speakers Group to the source Netradio....this is one of the elegant things about BSys4-based products.
Doing so the Speaker Group (in your case 2) with your BL5’ set as L/R (‘stereo’) will always be activated - from standby or when changing sources on the tv.
From the User Guide 😉
’Sources have default settings, for example, sound and picture that suit most situations but you can change these settings if you wish.
Select the source, press the red button and select the ADVANCED SETTINGS menu.
1 Here, you can also set a speaker group to be activated when you select the source.’
My answer went into moderation (for whatever reason?).
Please be patient!
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Think its easiest if you get the user manual: Link
First you create a speakergroup, where your BL5s are included and give that group a name.
You can then go into the sourcelist in the menu and step down to Netradio.
Press the red button on your remote to go to settings
You then go to advance and select you speaker group.
Remember to save.
My post ended up in moderation. Think its easier if you download the manual from B&O web
danielshen:Can you help to indicate the page no? Pls take a look at the screenshot:
and when you have that speaker group set to music then it's the default so it will work
if you get stuck, PM me and i can take you through on skype
