BV11-55: send NetRadio to lab5 automatically?
This post has 11 Replies | 1 Follower
danielshen
Posts 78
danielshen Posted: Thu, May 2 2019 3:48 AM
Dear,
Can we send the NetRadio sound to connected beolab5 automatically when I just push the BeoRemote? Currently I have to go to: list - speaker - and push 2
Daniel
Millemissen
Flensborg, Denmark
Posts 14,680
You can easily assign a specific Speakers Group to the source Netradio....this is one of the elegant things about BSys4-based products.
Doing so the Speaker Group (in your case 2) with your BL5’ set as L/R (‘stereo’) will always be activated - from standby or when changing sources on the tv.
From the User Guide 😉
Sources have default settings, for example, sound and picture that suit most situations but you can change these settings if you wish.
Select the source, press the red button and select the ADVANCED SETTINGS menu.
1 Here, you can also set a speaker group to be activated when you select the source.
Millemissen
Flensborg, Denmark
Posts 14,680
My answer went into moderation (for whatever reason?).
Please be patient!
danielshen
Posts 78
Can you send it again?
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, May 2 2019 2:00 PM
You can setup a speakergroup specifically for the netradio source.
danielshen
Posts 78
Can you kindly give me the menu step or TV screening photo? Many thanks!
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, May 2 2019 4:25 PM
Think its easiest if you get the user manual:  Link
First you create a speakergroup, where your BL5s are included and give that group a name.
You can then go into the sourcelist in the menu and step down to Netradio.
Press the red button on your remote to go to settings
You then go to advance and select you speaker group.
Remember to save.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, May 2 2019 4:27 PM
My post ended up in moderation. Think its easier if you download the manual from B&O web
danielshen
Posts 78
Can you help to indicate the page no? Pls take a look at the screenshot:
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, May 2 2019 5:26 PM
danielshen:
Page 21 for setting up a speaker group
Aussie Michael
Melbourne, AU
Posts 3,730
and when you have that speaker group set to music then it's the default so it will work
if you get stuck, PM me and i can take you through on skype
Aussie Michael
Melbourne, AU
Posts 3,730
You can also set the TV to off to it doesn’t come on
In that setting you get the green light and the TV moves to the music position (for my Avant gen 1) and the Avant speaker unfolds. But that won’t happen for a BV11 as there is no drop down speaker
Page 1 of 1 (12 items) | RSS
