Beovox S45 (type 6302) stands?
This post has 3 Replies | 0 Followers
Martynmcg
Posts 9
Martynmcg Posted: Wed, May 15 2019 9:28 AM
Hi
I have a pair of type 6302 S45s
These have the composite backs unlike the Mk.2
I have also notices that some of the Mk.1 S45s can also take the standard style B&O stands that seem common on these as they have threaded mounting points like the Mk.2s.
However the backs on mine have no threaded holes and instead have 3 slots running centrally down the speaker that look like they are designed to have the speaker hooked on to something.
So my question is did B&O make stands for this type of speaker? If so does anybody have any pictures of them as I can probably make some replicas up myself...
At a guess if they hooked on to a mounting point near the top and then the speaker rested against some rubber mountings further down this might work; I am not sure how different mounting arrangements affect the sound.
Martyn
priklep
Slovakia
Posts 103
priklep replied on Wed, May 15 2019 2:53 PM
Dear martynmcg,
here on Beoworld you can find info about DIY procedure of stands for Beovos S45-2 stands.
https://archivedforum2.beoworld.org/forums/t/30838.aspx
Here is the picture form  stand manual
Martynmcg
Posts 9
Martynmcg replied on Wed, May 15 2019 3:11 PM
Thanks for the reply however this is for the later S45-2 and I believe some of the other S45s however these wont fit mine.
I wondered if they made an earlier version of this stand.
Martyn
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, May 15 2019 4:19 PM
Martynmcg:
They didn't.
No stand for Type 6302.
Page 1 of 1 (4 items) | RSS
