Does anybody know why almost half of some 100+ photos turn sideways when downloaded onto my profile? (when you click on them on the actual thread they turn and present correctly!)
I'm trying to complete my house renovation thread but sideways photos just look terrible..
Iphone/Ipad pictures by any chance ?
Yes they are..
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Unfortunately an APPLE feature.... The only way i know to strip the (wrongly) embedded info, is a short detour through paint which my take a while with a 100 photos. I am sure there are other ways.
No I emailed them all from my iPhone to my gmail a/c - then saved them onto my pc. Then I logged into Beoworld and added each photo to my profile. None of the saved images are sideways on my pc but almost half appear to turn on one side when downloaded to the Beoworld profile from pc.
How annoying!
Brian:No I emailed them all from my iPhone to my gmail a/c - then saved them onto my pc. Then I logged into Beoworld and added each photo to my profile. None of the saved images are sideways on my pc but almost half appear to turn on one side when downloaded to the Beoworld profile from pc.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
BEOVOX141: Unfortunately an APPLE feature.... The only way i know to strip the (wrongly) embedded info, is a short detour through paint which my take a while with a 100 photos. I am sure there are other ways.
Are my pictures ‘sideways’?
If yes - you should use an iPad instead of your pc to follow Beoworld threads ;-))))))))
Millemissen:Are my pictures ‘sideways’?
Yes they were indeed, before you found a remedy....
Remedy....which remedy?
Millemissen:Remedy....which remedy?
How should I know? I do not own or use the device in question.
That I know....for sure.
However, I did not change anything - so no hidden remedy here.
No,- but for a while years ago your pictures were upside down or perhaps rotated cant remember.
Both of us know what the issue is so lets just leave it at that,
I really do not want to go trawling through PeterPans treads on a semi defunct danish website.
BEOVOX141: Both of us know what the issue is so lets just leave it at that, I really do not want to go trawling through PeterPans treads on a semi defunct danish website.
No, because that might have been the case with that ‘semi defunc website’ - and is history now.
We are talking Beoworld threads.....this was what the op/Brian meant, I guess.
You are talking to the wrong person Beovox.. they are my photos... not Millemissen’s.. ;-)
Brian, I agree because it happens to me and I can't figure it out.
If you all are done fighting, I'll try to explain the reason.
iPads and iPhones don't rotate the pictures they save to the "correct" orientation, they just add an EXIF header which explains the correct orientation for displaying the image. Other phones and most cameras (or their download software) actually rotate the image. Many systems just display the image and don't care about the EXIF info on orientation. So there's a good chance that a photo will be shown sideways (or even upside down if shot on an iPad, you don't usually hold your phone upside down).
--mika
tournedos:If you all are done fighting, I'll try to explain the reason.
Nobody's fighting and most know the reason for this. If it is a bug or feature is down to the usual Apple or Not discussion!
However so far I am the only one you provided a truly "daft", but working, Paint workaround, I am sure there are better ones?
And I dont mean the laconic "go buy an Ipad/phone" advice!
That’s exactly what I ended up doing - going through every photo using paint and saving a second copy.
Just a test.
How many of you see this picture sideways?
Which device do you use for viewing/browsing the Beoworld website site?
Is it different when someone uses the app?
Millemissen:Just a test. How many of you see this picture sideways? Which device do you use for viewing/browsing the Beoworld website site? Is it different when someone uses the app? MM There is a tv - and there is a BV.
Correctly on Win/PC but it does not look like native Ipad photo,- Scaled ?
Native Ipad/Iphone picture will always show up rotated, (based on the sensor of course 50%) on my computers.
That photo was taken with my iPad - I don’t remember whether horizontal or vertical.
It was then cropped in the Photos (iPad) app and resized using the PhotoResizer (iPad) app.
Stored to my Dropbox and from there put into the thread using the built-in ‘Options’ -> ‘Add’ -> ‘Choose Archive’, ‘Save’ method.
It could not get more iPadish, I guess 😁
