A young bloke in his early 20's with an expensive hobby..
Present:
Beovision 4-50 Full HD, Beosystem 3, DVD2, Beolab 8000 MK2, Beolab 7-2, Beotime alarmclock, Beosystem 2300, Beolab 2500, Beovision 8-40, Beosound 8, Beo5, Beo4 DTV
Sold:
BeoMaster 7000, BeoVox RL7000, BeoCenter 6-23 DVI, Beolab 4, B&O F1000 furniture, Beovision 8-26
Find out what the pitch and length is and goto Digikey.Com,- just to name one.
Flat flex, Ribbon jumper cables.
Another option is to simply replace the ribbon cable with regular soldered wires, not at the actual connector area but rather where you have some space to solder down the wire.. the signal usually originates somewhere a bit away from the connector.
BEOVOX141:Find out what the pitch and length is and goto Digikey.Com,- just to name one. Flat flex, Ribbon jumper cables. Another option is to simply replace the ribbon cable with regular soldered wires, not at the actual connector area but rather where you have some space to solder down the wire.. the signal usually originates somewhere a bit away from the connector.
