Beosound 8 - broken 20 pin ribbon cable
This post has 2 Replies | 2 Followers
8000Kristian
Posts 53
8000Kristian Posted: Mon, Jun 3 2019 6:08 PM
Dear Beoworlders Smile
I bought a cheap but faulty Beosound 8 a month ago, thinking the problem would be the long time without usage, and that an old iPod would bring it to life.
And it did. Sort of. The keypad had no control, and the light never came to life. The only control was on the old iPod.
So I thought that I might as well turn it off and dismantle the hole thing.
And just as I hoped. The ribboncable from the keypad to the main board had snapped out of its socket.
So now I think I have diagnosed it...
But. Huh?
Where do I find a new spare part? This might be a common part. But where should I buy it? Confused
A young bloke in his early 20's with an expensive hobby..
Present:
Beovision 4-50 Full HD, Beosystem 3, DVD2, Beolab 8000 MK2, Beolab 7-2, Beotime alarmclock, Beosystem 2300, Beolab 2500, Beovision 8-40, Beosound 8, Beo5, Beo4 DTV
Sold:
BeoMaster 7000, BeoVox RL7000, BeoCenter 6-23 DVI, Beolab 4, B&O F1000 furniture, Beovision 8-26
BEOVOX141
Denmark, West
Posts 711
Find out what the pitch and length is and goto Digikey.Com,-  just to name one.
Flat flex, Ribbon jumper cables.
Another option is to simply replace the ribbon cable with regular soldered wires, not at the actual connector area but rather where you have some space to solder down the wire.. the signal usually originates somewhere a bit away from the connector.
8000Kristian
Posts 53
BEOVOX141:
Dear BEOVOX141
Thanks for the link. I will have a look there!
I don’t want to try the soldering option, as I don’t have much experience with precise soldering. Big Smile
Present:
Sold:
Page 1 of 1 (3 items) | RSS
