Beomaster 1900 left channel louder than right channel
This post has 1 Reply | 0 Followers
Andreas
Germany
Posts 18
Andreas Posted: Sat, Jun 22 2019 3:41 AM
Hello,
sorry, my english is unfortunately not good
I restored a Beomaster 1900. Was in bad condition. Now everything works fine, but  its left channel is a bit louder than the right one. If I pull the Plug from toneboard and make the hum test, the hum is left channel louder too, so I think, it's not the toneboard (all sliders are in good condition) Headphone is the same.
What I have done til now:
I changed all ROE Caps, the two big caps, the rectifier, that little speakerswitch, the lamps and R249/R349. The idle is now 24mV over both R. The 15V power supply has its 15V.
Any Ideas?  Thank you
Andreas
Andreas
Germany
Posts 18
Andreas replied on Thu, Jun 27 2019 11:05 PM
Hello everybody,
the problem is solved. I found some more bad soldered points on several places. Done! And everything works fine now.
Nevertheless thank you.
Andreas
Page 1 of 1 (2 items) | RSS
