Hello,
sorry, my english is unfortunately not good
I restored a Beomaster 1900. Was in bad condition. Now everything works fine, but its left channel is a bit louder than the right one. If I pull the Plug from toneboard and make the hum test, the hum is left channel louder too, so I think, it's not the toneboard (all sliders are in good condition) Headphone is the same.
What I have done til now:
I changed all ROE Caps, the two big caps, the rectifier, that little speakerswitch, the lamps and R249/R349. The idle is now 24mV over both R. The 15V power supply has its 15V.
Any Ideas? Thank you
Andreas
Hello everybody,
the problem is solved. I found some more bad soldered points on several places. Done! And everything works fine now.
Nevertheless thank you.
