Beomaster 6500 Problems
This post has 12 Replies | 1 Follower
jaypink
Posts 55
jaypink Posted: Sat, Jun 22 2019 9:23 PM
Hi Guys...
Wondered whether you could assist me..? Ive had spare Beomasters for my 6500 systems, but theyve now all been used up..! I presently have three with issues.
No.1. Sparks and blows plug fuse instantly.
No.2. Does not recognise the MCP at all.
No.3. All works fine, will not allow control of the Beogram with the MCP. Beogram itself..?
Thanks, jay
Schletti82
Posts 128
You mein three different Beograms on one Beomaster, or three Beomaster (different ones)
jaypink
Posts 55
jaypink replied on Sat, Jun 22 2019 9:45 PM
So sorry..!   I mean Beomasters. Apologies, they are all spare ones that I have had.
Schletti82
Posts 128
First of all, please Look if the two extra pins are screwed in the plug of the Beogram.
if not, beogram could not work with the ir-Signal.
must be 7 Pins.
beomaster 1: bigger problem, think needs full service.broken amp section.
beomaster 2: capicators on the ir Board Must be replaced
beomaster 3::maybe everthing is fine, and the two Pins in the plug are missing.
otherwise we have to look further
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jun 23 2019 8:36 AM
Shorted mains transformer?
Option setting correct? (Bad backup battery?).
Bad or misadjusted IR receiver, bad capacitors or bad CPU.
Missing datalink pin or lead broken off in Beograms DIN-plug or bad protection diode(s) in the Beomaster (if fitted) or cracked solder joints at the Beomasters socket.
jaypink
Posts 55
jaypink replied on Mon, Jun 24 2019 10:15 PM
Thank you so much for the response, I'll get chance this weekend to take the BM's apart. Out of interest where is/Which one is the IR board..? I will definitely follow up on your suggestions... Thank you again
jaypink
Posts 55
jaypink replied on Mon, Jun 24 2019 10:20 PM
Thanks Martin...
1. I've got a spare transformer somewhere I'll exchange that.
2. Any forums/posts on Option setting/Back-up battery/IR issues....?
3. Any info/posts on protection diodes..?
Sorry to bother you with this Martin, your help is deeply appreciated.
Schletti82
Posts 128
Schletti82 replied on Mon, Jun 24 2019 11:13 PM
The IR Board is screwed directly on the front of the Beomaster.
the pack up Battery is inside the cpu platine. You have to open the metal case to see it.
the cpu Board Sites in the front where most of the cables run into
jaypink
Posts 55
jaypink replied on Tue, Jun 25 2019 9:30 AM
Thanks again for all the information, are there any details anywhere of the caps values so I can exchange them correctly. Can I buy the battery from Ebay..?
jaypink
Posts 55
Schletti82
Posts 128
Schletti82 replied on Tue, Jun 25 2019 11:49 AM
The battery is a normal 3v called 3032, you should find it nearly everywhere.
the value of the caps is written on the old ones. Take some with same specifications.
clean the ir diodes and in about 80% it should work again.
do the recapping before you change the backup battery.
maybe you do not have to change it.
Schletti82
Posts 128
Schletti82 replied on Tue, Jun 25 2019 12:22 PM
Why I write you should try before changing the backup battery is.
if you change the backup battery the tuning stations will be lost.
i don’t know how to explain in english correctly.
But for example you have a radio station which is really located on 89.0 you will find it after changing the battery maybe on 91.7 and so on.
if you’re fine with that no problem. But if you like to reset the tuner you have to shortcut your Beomaster.
I will not explain how to do that because if you do not really know what you’re doing you will destroy your amp instead of fix it.
if you really want to try you will find how to do that in the service manual on this side.
jaypink
Posts 55
jaypink replied on Wed, Jun 26 2019 9:59 AM
Thanks again for all of your advise, I will have a go at working on the IR board, battery and solder joints. Youve been very helpful... jay
Page 1 of 1 (13 items) | RSS
