H9 Gen 3 Low Volume
This post has 5 Replies | 0 Followers
Beo_Vision
Posts 21
Beo_Vision Posted: Sun, Jul 7 2019 4:54 PM
Hi Guys
Purchased a pair of Gen 3 H9’s last week and whilst I’m very impressed with the sound quality I find they are a little low in volume and could really do with a boost. I have only tested via Bluetooth and was wondering if anybody else has found this??
mawheele
Posts 258
Having the same issue connected to iPhone X. Any ideas anyone?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Have you both installed the B&O app where you can change settings?
The mk3 should be significant play with louder volume than the mk1. Mine H9i can play louder than needed.
Beo_Vision
Posts 21
I have the app and whilst there is some tweaking I feel the cans should be louder.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jul 8 2019 8:16 PM
Board issues - double post.
moxxey
South West, UK
Posts 5,359
Beo_Vision:
Hi Guys
Very strange - I didn't get this issue with my A9 and definitely do not with the BeoSound 2 I've recently purchased. If anything, it's often too loud.
Have you tried connecting directly through Spotify Connect and see if it makes a difference?
Page 1 of 1 (6 items) | RSS
