Beolab 7.2 with HDMI ARC
This post has 49 Replies | 5 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
That is the unit I used.
To make a bracket, just get a metal plate and measure where the holes need to be 😀
tuttivini
Posts 186
tuttivini replied on Sun, Jul 12 2020 8:26 AM
@leosgonewild: Thanks!
Can you tell anything about the 'sound quality', coming from the ARC-adapter?
tuttivini
Posts 186
tuttivini replied on Tue, Jul 14 2020 1:09 PM
Done!!!
Placed the Beolab 7.1 on a self made bracket to the wall and used the same 'speaker-cloth' on the grill, matching the Beolab 8000's.
All wires directly invisible into the wall, going to the Playmaker, hidden underneath the shelf.
Very happy with the result.
OldJack
Split
Posts 371
OldJack replied on Tue, Jul 14 2020 2:22 PM
Beautiful Big Smile
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
leosgonewild
Helsinki, Finland
Posts 2,373
Very nice Big Smile
dcfbeo
Posts 2
dcfbeo replied on Mon, Oct 19 2020 11:07 AM
Hello, have you or anyone else found an alternative ARC extractor to the one posted by leosgonewild?
I have been using the same ARC extractor which initially worked well but increasingly I've been getting a popping sound when changing channels or as a programme goes into an ad break. Works great otherwise, but the pops are annoying.
Tried another extractor by Mypin on Amazon which made no popping sound but the volume couldn't be controlled.
Set up is Samsung TV to Beolab 7.1 via ARC to 3.5mm jack.  Going to try ARC to RCA to see if that makes a difference.
Unfortunately Beolab 7.1 direct to TV headphone socket makes a loud bang when the TV is turned off - but works great otherwise, so it seems ARC is the best option.
leosgonewild
Helsinki, Finland
Posts 2,373
The RCA output is clean. But it has lower sound.
dcfbeo
Posts 2
dcfbeo replied on Sat, Oct 24 2020 10:57 AM
Thanks a lot. I concur. I’ve now added a female 3.5mm to rca to convert the headphone connection to an rca connection on the arc box and no more pops.
volume seems good for now, will try a few different sound options to check it out
acme
Posts 6
acme replied on Tue, Oct 5 2021 2:15 PM
Hello everyone,
My BV7-40 MKII passed away (black screen as so many other) and for sure it was my last B&O TV but I would like to use the Beolab and the stand for my new TV.
I didn't find a reseller for the RCA cable in UE, thus, I am going to buy 8 polet DIN and RCA and make it. Are you still using the arc decoder ?  any advice on the hardware ?
Thank you
Peter Pan
Posts 2,088
Page 2 of 2 (50 items) < Previous 1 2 | RSS
