Hi all,
I’m having a NL setup: Beosound Essence MKII, Beosound 2 new, M5.
Some CX100 stored. I want to use them
for outdoor, water protected. Any ideas to integrate them cheapest way?
My father too. But how to connect?
stampfki: ... how to connect?
... how to connect?
Use a single Essence PL socket, via RJ45 to Powerlink: https://soundsheavenly.com/bang-olufsen/31-325-rj45-to-powerlink-compatible-all-in-one-cable-convert-new-2013-ethernet-powerlink-to-traditional-8-pin-din-powerlink.html#/9-length-18m
To a Beolink Passive: https://www.beoworld.org/prod_details.asp?pid=981
Then via speaker cables: https://soundsheavenly.com/beovox-passive-unpowered-loudspeakers/24-1-2-pin-din-beovox-cx-speaker-cables-pair-also-for-beovox-2500-and-rondstraler.html#/5-length-5m
... to the CX100s
I'd be tempted to dope the paper cones on the woofers with something, PVA or a black liquid that dries like a soft rubberized finish, some speaker repair shops sell such. Just to make the paper cones last longer.
Jeff
If I don’t need multi room integration. Is the playmaker also an option?
Can I actually use it with the actual app which I use for my other NL stuff?
stampfki: If I don’t need multi room integration. Is the playmaker also an option?
Yes, but you'd still need an amplifier - i.e a Beolink Passive. The same connectors as I already suggested would be required and the Powerlink output from the Playmaker would automatically turn on the Passive when you started to Airplay to it.
(I can't answer your other question as I do not know enough about NL!)
