Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
In my files area are pics of what I built. It's unsafe junk, but drove a Carver M400 cube from a BeoCenter 2500 for years. [Edit: deleted]
B&O used to make an auxillary box to do this,although it wasn't designed for Powerlink,and needed 12v to trigger it,whereas the Powerlink trigger is 5v.
I think Steve at Sound's Heavenly does something for this purpose though,as often Beoworlder's want to drive an auxillary power amp.
Send him a message explaining what you need?
Nick
Hi DMacri
solderon29: B&O used to make an auxillary box to do this,although it wasn't designed for Powerlink,and needed 12v to trigger it,whereas the Powerlink trigger is 5v.
This was the box - they still come up on eBay occasionally: https://www.beoworld.org/prod_details.asp?pid=1246
.. and mine worked fine with a Powerlink 5v trigger, supplied by the RJ45 socket of a Playmaker to turn on a BM900 as its amp!
A couple of alternatives:
- This trigger circuit design is posted in the Beotech section of this site: https://www.beoworld.org/beotech/circuit.htm
- You could possibly use one of these with the Beomaster in the 'master' socket and the valve amp connected to one of the 'slaves': https://www.amazon.co.uk/CrazyGadget%C3%82-Automatic-Energy-Protected-Extension/dp/B00YZ50CE0/ref=pd_sbs_23_1/261-0402616-5327328?_encoding=UTF8&pd_rd_i=B00YZ50CE0&pd_rd_r=22113fae-cd85-49a0-94e7-01dba465ff54&pd_rd_w=7QfOB&pd_rd_wg=VZ1go&pf_rd_p=18edf98b-139a-41ee-bb40-d725dd59d1d3&pf_rd_r=388RY3ZS5GQ2B7Q8T3GS&psc=1&refRID=388RY3ZS5GQ2B7Q8T3GS
Here's a remote switch for sale in the US: https://www.ebay.co.uk/itm/Bang-Olufsen-B-O-Remote-Mains-Switch-4001-Remote-Power-Switch-Original-Box/223461957415?epid=1935044908&hash=item34075edf27:g:XtYAAOSwoutcmxpD
Guy:- This trigger circuit design is posted in the Beotech section of this site: https://www.beoworld.org/beotech/circuit.htm
Hi DMacri,
It sounds like you have a few options there. Please let me know if you need something to be built and I can sort this out for you.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
