Anyone here have one for sale? preferably shipped within Europe?
Thanks!
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Which one are you looking for? There are plenty of different types. What is the intended use?
Kai
Right!
It is to be attached to an Arduino board for home control/automation. It should be able to receive IR commands from a BeoRemote One.
Don't know what type that should be, but I guess one of the later models?
I came across an BeoLink PC2 with an eye on ebay, but don't know if that would suit me...
Hi there,
If it's just for IR, basically any IR-eye will work. Use 5v as supply with a 10K pull-up resister to data, and then of course ground.
If you intend to use the buttons on the IR-eye, my own experiences is that it is by far easiest to work with the latest model (the one with JOIN on top), since it uses regular TTL commands, whereas all the others use i2c.
Didn't know the ones with JOIN were actually different from the ones with TIMER on top, thought they were pretty much the same.
Trust me ;)
I do :-)
But since the buttons are none of my concern, I guess any eye will do.
The BeoLink PC2 kit seems to have an eye without buttons, is that correct?
The eye used for PC2 is AFAIK the same as for BeoSystem3 (without auto-contrast). You can use that. Here's an overview of the different eyes:
https://www.dropbox.com/s/hppbaea7f7bgpz9/IR%20eyes.pdf?dl=0
I have a few of the ones without the writing on if you need one. These were for the old Plasma TV's from memory.
Happy to give you it for the cost of shipping and a very small donation to BeoWorld (every little helps!)
Lee
That is a generous offer which I'll gladly accept!
Should we exchange information through pm?
Got your message. I packed and posted it a couple of hours ago. It's on its way!
Fantastic!
Please do let me know how to cover the shipping costs :-)
9 LEE: I have a few of the ones without the writing on if you need one. These were for the old Plasma TV's from memory. Happy to give you it for the cost of shipping and a very small donation to BeoWorld (every little helps!) Lee
Hello Lee, Can you offer or sell me an IR-Eye for my Beolink Passive (1656) with wall mount?
Best regards
wilfried
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
