Can anyone suggest an adapter or a procedure for connecting 1986 Penta 1 type 6603 speakers to a non-B&O system?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Thanks Dom!
Yes, you can use these superb speakers with any amplifier or receiver, here are all the options!
If your receiver has pre-out sockets (these MUST be variable, volume-controlled outputs, NOT Tape or Line outputs), then you can connect a pair of Beolab Penta speakers to these sockets using this cable:-
https://soundsheavenly.com/line-in-connection/av-processor-pre-amp-sonos-to-beolab-rca-line-in
However, if your receiver doesn't have pre-out sockets fitted, you can still connect the speakers by one of the two methods below:-
1) Connect two speakers to the headphone socket of the receiver with this cable: http://soundsheavenly.com/line-in-connection/77--trs-2rca-.html
2) Connect two speakers to the red and black speaker terminals on the back of the receiver using this special Attenuated Converter: https://soundsheavenly.com/line-in-connection/power-amplifier-to-beolab-line-in-attenuated-convertor-kit and then use this cable to connect the speakers to the output sockets of the Converter: https://soundsheavenly.com/line-in-connection/av-processor-pre-amp-sonos-to-beolab-rca-line-in
Option 1 is cheaper, but the cable will be visible at the front of the receiver and this will disable any other speakers connected to the receiver. Option 2 allows the cables to be hidden and the Beolab speakers can be used along with your other speakers for surround sound if required.
Please set both speakers to “Auto” mode using the small switch on the hinged front panel.
If you have any questions, please ask!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Appreciate the help.
Chose Option 2. Parts ordered. Thank you.
Please ask if you need any further help!
