I need to move my BeoVision 7-40, which is mounted on a motorized floor stand.
Can anyone give me any tips on how best to remove the TV from the stand i.e. do I need any special tools?
Thank you,
GC
Graham
Slightly tilt the stand and slide a towel under the base. You can now simply pull the towel and the TV will tag along. Easy as 1.2.3...
My wifes idea actually, she is a nurse and needs to move heavy objects (people) in a smart way Even the 7-55 can be moved this way!
BEOVOX141: Even the 7-55 can be moved this way!
Razlaw:Even on carpet?
There might be the impossible case, but I have moved an AV9000 on an american carpet with the soft carpet cushion underneath this way.
Tilt the steel base with a crowbar, and place the towel. 3/4 coverage should be enough, and you are good to go!
Slide it in from the side if you want it back up against the wall.
