Beovision 6 26 link to speakers/sound
This post has 12 Replies | 1 Follower
brunetto77
Posts 35
brunetto77 Posted: Sun, Aug 11 2019 3:25 PM
Hello, what's the best way to connect a pair of beovox speakers RL60.2 to a Beovision 6 26 TV? Will you need a separate amplifier for it? Not having hdmi at the back I've read that if you use a normal dvi to hdmi converter, you won't get any sound so I was thinking to use external speakers but not sure this is the best idea.
I've searched but couldn't find anything much helpful.
Many thanks
Bruno
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Aug 11 2019 4:16 PM
Firstly you are right in that the DVI input does not accept audio.
If you want to feed hdmi to the TV, then you could use an hdmi audio extractor such as this: https://www.amazon.co.uk/aoeyoo%C2%AE-Analog-Converter-Digital-Extractor-White/dp/B00NAJ4UM2/ref=sr_1_37?keywords=hdmi+audio+extractor&qid=1565536235&s=gateway&sr=8-37
And then feed the sound to the two (L&R) phono sockets in the rear panel, and use a 'hdmi to DVI' cable for the picture into the TV. You will then be able to get sound and picture by selecting 'PC' on your remote.
The audio extractor in the link has the added advantage of removing 'hdcp' - which is a great help when trying to watch protected hd content on a TV that is not HD ready.
With this setup (which is what I use) you will not need external speakers.
If you wish to add you RL60s as external speakers anyway, then a good solution would be to add a Beolink Passive to act as an amplifier.  You would connect the passive to the TV by Powerlink, and then connect your speakers also.  Switching on the TV would also then trigger the amplifier to turn on.
brunetto77
Posts 35
That's great Guy, thanks so much for the very informative response. One other question please is how to set up PC from the remote control. I'll use a beolink 1000. What's a beolink passive then, not a big expert on this as you can see.
Thanks again.
Bruno
brunetto77
Posts 35
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Aug 11 2019 4:42 PM
You can select PC on your BL1000 by pressing SHIFT then STORE.
And a Beolink Passive is one of these: https://www.beoworld.org/prod_details.asp?pid=981
You can pick then up quite cheaply on eBay. (And you just need the main unit - not the IR sensor!)
For Powerlink cables, I suggest speaking to Steve at Sounds Heavenly, our site sponsor below.
Got to nip out now, but happy to answer further questions later.
brunetto77
Posts 35
Perfect! Thanks again!
Bruno
brunetto77
Posts 35
brunetto77 replied on Thu, Aug 15 2019 11:24 PM
I'm actually trying to get a second hand beovision 6 26 but it doesn't come with any stand. Will I be able to use it on top of a  small table or will it fall? It may seem a silly question butI haven't got a clue 😊
brunetto77
Posts 35
lawrencejmcook
Posts 742
Hi Bruno,
I own a BV6-26. Whilst it is possible to stand it upright on a flat, stable surface without the proper table base, I would not recommend this, as it would block the bass reflex ports that vent on the underside of the tv.
For the best sound, buy one with either the static table base, motorised table base or motorised floor stand. Wall brackets available too. You can find all of these things cheaply at the usual online marketplaces.
Kind regards,
Lawrence
brunetto77
Posts 35
Thanks Lawrence, the problem is that I live in Scotland and I can't never find anything here. Everything is in England and most is for collection only. I once drove to collect an MX7000 and it was quite a challenge. Even if it was delivered then, there's a possibility of damage in transit. I guess I'll have to wait and hope for something turning up locally. ☺️
altist
Posts 72
altist replied on Fri, Aug 16 2019 8:01 AM
Hi Brunetto,
  I have a spare motorised floor stand for a beovision 6-26 that I would happily sell you...I’m based in Stirling if that works for you..send me a message if this is of interest. Best wishes.
altist
Posts 72
Hi Brunetto,
lawrencejmcook
Posts 742
brunetto77:
Bruno,
I know exactly what you mean! I was aching for a red BeoLab 7.2 at a very competitive price in Ayrshire!! πŸ˜„
Good luck with your search - looks like you have an offer.
Lawrence
Page 1 of 1 (13 items) | RSS
