Suggestion for HDMI to RGB SCART (not CVBS SCART)?
This post has 24 Replies | 1 Follower
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Mon, Aug 12 2019 8:20 AM
Been looking around for some kind of decent HDMI to SCART (RGB output) and while there several cheap ones available for around 15-26 Euro range from the same manufacturers which produce the SCART to HDMI converters which only makes use of the SCART CVBS instead SCART RGB - I would like to reach out if anyone here has a suggestion for a decent converter/scaler?
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, Aug 12 2019 8:39 PM
Well, it might be easier to find hdmi to s-video converters which at least provides far better picture image compared with composite video. Anyone have suggestion for devices?
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Mon, Aug 12 2019 8:53 PM
Out of curiosity, what do you need it for, perhaps there is another way?
jordanius
Posts 5
jordanius replied on Tue, Aug 13 2019 4:05 AM
Hey Kim, I explored this exact scenario a couple of years ago as a way of extending the life of my SCART only B&O gear. The generic HDMI to composite/svideo adapters are universally average due to the limitations of the low res signal.
I highly recommend one of these
http://arcadeforge.net/UMSA/UMSA-Ultimate-SCART-Adapter::57.html?language=en
Pair it with with a HDMI VGA adapter and you are golden. The RGB signal you want is 15khz 480i/576i which can be easily generated with a Raspberry Pi. People write off Beovision 5's as essentially worthless but I was astonished with mine once I had this up and running. Razor sharp, deep blacks and super punchy colours. Try it out.. you will be amazed with the results !
Manbearpig
Posts 908
I'll try that out as well to connect the Beosystem 3 to my old avant. Sounds like a good solution! Thanks!
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, Aug 15 2019 9:35 AM
Do you know if on the B&O TV it automatically adjusts the screen to 16:9? - I've been using one of the cheaper ones for my BV6 in the bedroom - resolution is not good with Apple TV for text, but okish on a small screen for movies. Problem is that everytime I switch it on I have to then select Format 3 - tried all settings in the setup on both the TV and Apple TV but still end up having to manually switching to Format 3.
Manbearpig
Posts 908
Manbearpig replied on Sat, Aug 17 2019 10:26 AM
May I ask how exactly you generate the 15khz signal from a video processing engine? Kai
matador43
Posts 1,373
matador43 replied on Sat, Aug 17 2019 10:51 AM
matador43
Posts 1,373
matador43 replied on Sat, Aug 17 2019 10:52 AM
Andrew:
A solution to that may be a Beo5/6 which can adjust the format automatically based on source selection on top of controlling the Apple TV and the Beovision.
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Aug 17 2019 11:09 AM
Andrew:
You'll need something that sets pin 8 of the SCART to 6V (actually 4.5 - 7V) - this should automatically set the TV to 16:9.
(EDIT: It may already be trying to do this, but will only work if your SCART lead is fully wired, i.e all pins connected - have you checked?)
Andrew
Frinton, UK
Posts 917
Andrew replied on Tue, Aug 20 2019 9:51 AM
Hi Guy - no the output from the converter only outputs Video and Audio L/R - I think as the TV is getting quite old, I'll probably look at replacing it in due course, thanks though for the replies.
Manbearpig
Posts 908
Manbearpig replied on Tue, Aug 20 2019 12:58 PM
That's the path that most of us go sooner or later. However, I still stick to my old Avant 32 RF because it is such a beautiful furniture - much better than any flat screen that I have seen. But it is all a matter of taste, I guess. I mean, B&O has done fabulous flat panels, but the old CRTs were in their time way more ahead of their competition in terms of style.
I'd still like to know, how you put that solution of jordanius to practice. Most of us will use some AV processing machine and I'm not too sure whether those are able to put out 15khz.
Kai
Andrew
Frinton, UK
Posts 917
Andrew replied on Tue, Aug 20 2019 2:08 PM
Totally agree about the Avant - my old one was better than my BV8 at most things other than displaying text from Apple TV and not having an HDMI socket.
jordanius
Posts 5
jordanius replied on Thu, Oct 24 2019 4:54 AM
@manbearpig - You can generate a true 15khz RGB signal with a raspberry pi by adding two lines to the config.txt file as described here
https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
To get 16:9 576i on my BV5 I use
hdmi_group=1
hdmi_mode=22
To everyone who is linking to the generic hdmi->scart adapters remember that scart is just a connector which supports a number of standards. These cheap adapters use composite or svideo. The only way to improve the picture is by seeking out something such as a PI which can output a RGB signal.  Think of RGB as being like VGA with separate lines for the red/green/blue versus composite with all picture information being mashed together and transmitted down a single wire. The difference is night and day.
Manbearpig
Posts 908
I see, but that's a rather special solution then, isn't it? It only allows for a particular source and most of us will run different setups with different sources, but still needing such converters. My source is the Beosystem 3. With that, the solution apparently doesn't work then?
Cheers,
Kai
alvinedyvane
Portsmouth
Posts 17
Hi all, I am too finally looking at this. Really cant bring myself around to getting rid of my Beovision 5 at home so am moving this to my office but need to bring it inline with 2020.
So is anyone aware of a YouTube video on installing a Raspberry pi to a Beovision and what products would i need to purchase? It would be so much easier to watch and follow rather than trying to do this from someones written experienced knowledge?
Appreciate your help.
Alvin
cclr
Posts 9
cclr replied on Thu, Apr 1 2021 10:09 AM
Hello jordanius,
Many thanks for your post, it is very interesting, I just purchase a fantastic Beovision 5 only with scart and for now I use it with a simple HDMI to scart converter (https://www.amazon.fr/gp/product/B01AO0XC7I/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1).
This is correct but could be better, of course, I was unable to find a HDMI to RGB scart and I will certainly get what you suggest
and pair to a HDMI to VGA (probably a HDFury).
However, I had also in mind a Rasberry Solution (for example http://arcadeforge.net/Pi2Jamma-Pi2SCART/PI2SCART::264.html)
but it seems, it cannot work as I understand, this can work ONLY if the Rasberry is the source, in my case, I use a Google TV as HDMI source and the idea was to use the Rasberry + Pi2SCART as the HDMI to RGB converter.
Can you confirm this is a wrong solution?
In this case, I will go for UMSA solution, have a good day
Loic
(Beovision 6-22, beovision 7-32, beovision 10-32 and for just 1 week a beovision 5)
Daniel
Italy
Posts 14
Daniel replied on Sun, May 9 2021 11:30 PM
cclr:
hello, I have to do this too did you try UMSA + fury hd 3 and did it work?
cclr
Posts 9
cclr replied on Mon, May 10 2021 12:57 PM
Hi Daniel,
Actually, this solution did not work, especially the part with Umsa scart adapter, this item require 15 khz as vga input and was unable to find out how to get it, I still have the adapter and I can sell it :-)
I also purchase a HD Fury 3 (HDMI to VGA + sound) which did not work properly but I was able to return it.
I thought I had an alternative solution when I found a adapter 5 RCA (RGB + sound) -> Scart but the adapter from Conrad did not work also....
At the end, I used a hdmi --> S-video + sound which is better that CVBS, it just require to use the beovision with camrecorder input.
With that Beovision 5 is now just fantastic and I was lucky to get it for a very good price!
Daniel
Italy
Posts 14
Daniel replied on Wed, May 12 2021 1:19 AM
thank you very much for your response with your experience you avoid me a purchase equal to me too, I found a converter model (ie I found its instructions) that does what we need but it is discontinued and unobtainable used, then on ebay I found this VGA2SCART - VGA to SCART converter (RGBHV to RGBs) which also works at 31 khz so now you have to find a scaler from hdmi to rgbhw (which the fury 3 does) I just have to understand if at 31khz?
Daniel
Italy
Posts 14
Daniel replied on Wed, May 12 2021 2:02 AM
I wrote to the guy from VGA2SCART - VGA to SCART Converter (RGBHV to RGB) to ask if my thinking is correct. i will tell you the answer here.
I found a YPbPr to RGB SCART transcoder / converter I purchased was the last one (fury 3 from a component output which I believe is YPbPr)
TWG
Posts 1,672
TWG replied on Wed, May 12 2021 6:47 AM
Maybe it helps you to have a look at the professional av/broadcasting solutions from e.g. Gefen, Blackmagic Design, Matrox etc.
They're built to do their job reliable(!) even in harsh movie production environments.
Here's a Google translated version of a german provider to have a small overview:
https://translate.google.com/translate?sl=de&tl=en&u=https://teltec.de/kamera-produktionstechnik-konverter-processing/?p%3D1
Examples:
1.) Gefen HDMI -> S-Video & Composite converter:
https://www.gefen.com/product/hdmi-composite-s-video-scaler-GTV-HDMI-2-COMPSVIDSN
2.)  Roland Video converter (discontinued, Example):
https://proav.roland.com/global/products/vc-30hd/
As you can see there could only be a small problem due to the BNC connections featured on many of the professional devices: You'll need cable adapters from e.g. the BNC connection (like the ones seen on the Roland device) to your TV / scart plug etc.
Daniel
Italy
Posts 14
Daniel replied on Thu, May 13 2021 8:55 PM
The problem is finding these equipments have been discontinued for years.
Gefen EXT-DVI-2-RGBSS this seems to be the best solution, ordered one.
I am a computer technician it is not a problem to build a cable.
Daniel
Italy
Posts 14
Daniel replied on Fri, May 28 2021 10:22 PM
Gefen EXT-DVI-2-RGBSS arrived € 100 ebay germany.
excellent solution! 1080P hdmi input scale to 576i you can see really well even the text reads well finally.
you have to build a cable with 4 bnc to scart,
give 1.5 volts (AA battery) between pins 16+ and 18 gnd if it is to make the TV recognize the RGB signal input.
I have to try with other devices to understand if you need to give a voltage for the FORMAT setting (16/9)
automatically but I don't think it's a big problem you can also adjust it from beo4.
I still have to connect the audio extractor and make the final cable.
then I'll watch a movie and put some photos of the finished work.
Page 1 of 1 (25 items) | RSS
DigiCert Secured Site Seal
