BeoLab 8000 - Amplifier PCB connector for Line-IN; which pin is what?
This post has 17 Replies | 1 Follower
KolfMAKER
The Netherlands
Posts 176
Silver Member
For one of my projects I need to connect an external audio source directly to the Line-IN connector on the amplifier PCB. This is a 3-pin connector of which I added a picture to this post. In the picture, it is the left connecter in the row of three.
What I would like to know is what all three pins connect, which is audio left/right, ground and what is the third pin for?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Aug 15 2019 11:08 AM
A general handrule is, that the warmest color is right.
I'd say;
Pin 1 Red - right
Pin 2 White - left
Pin 3 Black - ground.
You need all three to transfer a stereo signal.
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Thu, Aug 15 2019 11:12 AM
Thanks for your response Martin.
Does this mean the inegrated amplifier is stereo?
I assumed it was mono to have stereo with two speakers combined.
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Thu, Aug 15 2019 12:26 PM
P4-1 is the audio signal that starts the autostart when you are not using PL cables.
P4-2 is the audio signal that goes to the crossover board
P4-3 is ground
Dillen
Posts 13,191
Dillen replied on Thu, Aug 15 2019 12:36 PM
Oh sorry, I forgot the channel selection is done upstream from here.
Pin 1 is for the autostart
Pin 2 is audiosignal
Pin 3 is ground
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Thu, Aug 15 2019 2:17 PM
Thanks a lot!
There are two things I try to understand:
  1. Does "Autostart" mean that the BeoLab 8000 speaker will switch from 'Standby' to 'On' when an audio signal is detected on P4-1?
  2. Is the P4-2 signal the Left or Right channel signal that is being processed to sound one can hear? Also meaning, the P4-1 signal is only for switching, not for hearable sound?
Dillen
Posts 13,191
Dillen replied on Thu, Aug 15 2019 3:12 PM
1. Yes.
2. The option switch sets the left/right/Phono input. And yes, P4-1 is only used for switching the amplifier on.
Look in the servicemanual. This is one of very few active speakers that B&O released the circuit diagram for.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Thu, Aug 15 2019 7:02 PM
You might notice the auto switching, has a way to aggressive (short) time constant. Watching a movie is pretty much impossible, the BL8000 goes on and off all the time. click, click, click....Big Smile
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sat, Aug 17 2019 12:42 PM
Thanks all for responding. Happy to have gotten this knowledge from you!
One more thing. Obviously, I am going to use the P4 connector (Pins 1 to 3) for my project. So I will have to order a (3-wire) cable with connector that fits to P4.
Does any one know if this cable has a specific name/type?
(Helps me ordering the right one)
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sun, Aug 18 2019 1:41 PM
Is the P4 connector a "JST 2.0 3-pin" connector?
KolfMAKER
The Netherlands
Posts 176
Silver Member
Svenni
Berlin, Germany
Posts 48
Svenni replied on Tue, Aug 20 2019 11:40 AM
Would it be possible to use a customized PL cable to circumvent that issue?
Beoplay A2
Beoplay Earset
Beoplay H6 (Gen 2)
Beoplay S3 (pair)
Beoplay S8
Beovox CX50 (2 pairs)
Beovox RL 6000
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Wed, Aug 21 2019 5:17 PM
Hi Svenni,
Thanks for your suggestion. I am working on connecting the BeoLab 8000's amplifier PCB with my own WiFi & streaming electronics. I need a direct connection internally PCB to PCB, to make my system truly wireless. A PL cable would not work for my purpose.
Thanks anyhow.
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sun, Aug 25 2019 6:20 AM
Hi Dillen, I know what the numbers mean. But I am not sure which pin has which number.
The connector that goes into P4 has a brown, white and black wire.
Having the white wire in the middle, this must be pin-2.
But can you please tell which pin number brown and black are?
Dillen
Posts 13,191
Dillen replied on Sun, Aug 25 2019 8:55 AM
Look at the board.
It's printed there, visible in your photo.
Brown 1
White 2
Black (screen) 3
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sun, Aug 25 2019 7:17 PM
You are right, thanks!
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sun, Aug 25 2019 8:32 PM
Hi Dante, one thing I don’t understand. P4 is connected to the cinch connector in the stand/foot of the speaker. But the cinch only has two wires (one for Left or Right and one for Ground.
So to what is the 3rd wire connected to (so the Autostart functions)?
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Tue, Aug 27 2019 6:48 PM
Hi Dillen, one thing I don’t understand. P4 is connected to the cinch connector in the stand/foot of the speaker. But the cinch only has two wires (one for Left or Right and one for Ground).
So to what is the 3rd wire connected to (that makes the Autostart function work right)?
Page 1 of 1 (18 items) | RSS
