hi all,
I recently purchased a Beolink Converter, Networklink
masterlink.
I wanted to knstall today. Opened the box and no manual in.
does anyone has an manual. This thing seems to be quiet powerful with a lot of connections.
or do I just connect my Beosound 9000 and my beovplay V1 with it and it all works automatically???
thanks,
stefan
Hi Stefan
It wouldn’t work right off the box like the other converters... you can find all there is to know in the Beolink handbook:
https://beointegration.com/uploaded/EN-BeoLink-handbook-v1-7.pdf
Søren
@Steve
You asked questions in the B&O app thread about using a Moment in an integrated setup. I thought it might be more appropriate to respond in this thread where it could be more useful to others, too.
I connected an NL/ML converter via ML to my BeoVision 10. By doing so, the BeoVision 10 can appear via NL as an available BeoVision for my Moment to integrate with it to use that BeoVision's speakers. This selection is done on the Moment when you take off the back panel to get into the settings. Then you make the selection to use a BeoVision's speakers under the "sound" and then "speaker setup" menu.
For the O.P.: It's true that the regular manual for the converter is not very detailed. There is a MUCH more detailed manual available. If you PM me, I'd be happy to send it to you.
I forgot to add that I have my Moment connected to NL via CAT 7 -- as I have all of my NL devices connected by cable rather than wifi.
I have my NL/ML Converter set as A.Master with my BeoVision 10 set as V.Master. I use the NL/ML converter's web interface to map the Moment (and other NL devices' sources) as available on ML as CD, A.Mem, etc.
BTW, I'm getting ready to add my FIFTH NL/ML converter! I'll then have the following legacy ML devices available on NL:
BeoSound 9000
BeoSound 5
BeoCenter 2
BeoMaster 5500 with BeoGram 9500 and BeoGram 3000 turntables
BeoSound 2300
Stefan:How can I "enter" this Web interface???
The web interface should start. Standard user/password: admin/admin
Or install the Bang & Olufsen app. Be sure the BLC is connected to the router and is running. Add the BLC as source in the app; choose the BLC; select "product settings" and " about" - the IP address is shown. etc....
Note: I refer to the Beolink Converter NL/ML as BLC.
Carolpa: Or install the Bang & Olufsen app. Be sure the BLC is connected to the router and is running. Add the BLC as source in the app; choose the BLC; select "product settings" and " about" - the IP address is shown. etc.... Note: I refer to the Beolink Converter NL/ML as BLC.
Be aware that you can’t use the Bang & Olufsen app any more... they removed that functionality some updates ago.
Instead you have to use the “old” BeoSetup app.
Soren: Carolpa:Or install the Bang & Olufsen app. Be sure the BLC is connected to the router and is running. Add the BLC as source in the app; choose the BLC; select "product settings" and " about" - the IP address is shown. etc.... Note: I refer to the Beolink Converter NL/ML as BLC. Be aware that you can’t use the Bang & Olufsen app any more... they removed that functionality some updates ago. Instead you have to use the “old” BeoSetup app. Søren
I prefer a web browser to change settings on a BLC..... still the easiest.
Dear all,
thank you all for the advices. I will try to figure out set the system up.
Thanks.
Stefan
beojeff:@Steve I forgot to add that I have my Moment connected to NL via CAT 7 -- as I have all of my NL devices connected by cable rather than wifi. I have my NL/ML Converter set as A.Master with my BeoVision 10 set as V.Master. I use the NL/ML converter's web interface to map the Moment (and other NL devices' sources) as available on ML as CD, A.Mem, etc.
Trying to set it the same way as you do. I now have a Moment, a BV5 and a ML/NL converter. I have the ML/NL connected to the BV5 via ML. I don't have any cable between the Moment and the ML/NL and also not between the Moment and the BV5. I have set the ML/NL as BLGW via SW in the settings of the Moment.
I still need to configure the ML/NL in its settings.
SettingML enabled: yesML role: A-MasterNL connect primary to: MomentProduct controlled by Apps: V-MasterPL enable line-in sense: off
Sources visible on ML: I think I know what this does, but this is only needed if I use the Beo4 to select channels from NL. For example, I can select "Radio" to play "TuneIn from my A9" if I select it on the Beo4. I have not succeeded to configure it to play from the Moment. How I can configure the ML/NL to pick up signals that the Moment joined.
Experiences mapped to NL: also not relevant unless I'd like to send the TV audio signal to NL devices
And what I cannot get to work at all is for the BV5 via ML/NL to basically act as a Moment speaker. I.e., the BV5 plays whatever the Moment plays (i.e., joins, selects on its own, etc.). And ideally even auto-joins / auto-plays.
Mmh... No idea why, but the Moment now no longer shows up in the "multi-room" view of the B&O app. It used to before. Could this have been caused to some of the settings I have done in the ML/NL?
beojeff:I connected an NL/ML converter via ML to my BeoVision 10. By doing so, the BeoVision 10 can appear via NL as an available BeoVision for my Moment to integrate with it to use that BeoVision's speakers. This selection is done on the Moment when you take off the back panel to get into the settings. Then you make the selection to use a BeoVision's speakers under the "sound" and then "speaker setup" menu.
I think I got what you have done. Unfortunately. no BV shows up in the selection menu. Issue may be that my BV may not be in V.Master mode? How do I set this up and any negative impact from it?
With your setup, you can integrate BVs, but can not integrate with a NL device like an A9. I saw in the other thread that you are trying to make this work as well.
Both setups would be interesting for me. I have two BVs. I can only setup one BV as V.Master, right?
beojeff:It's true that the regular manual for the converter is not very detailed. There is a MUCH more detailed manual available. If you PM me, I'd be happy to send it to you.
lawrencejmcook: beojeff: It's true that the regular manual for the converter is not very detailed. There is a MUCH more detailed manual available. If you PM me, I'd be happy to send it to you. Hi Jeff, I too have an NL/ML converter, and would appreciate understanding it better. Would you mind sharing a copy via PM? Kind regards, Lawrence
Hi Jeff,
Kind regards,
Lawrence
I would also appreciate to PM receive a copy.
thanks in advance
Hi Steve77, hang in there.
Some brief thoughts, if you are still stuck.
For the Moment being in the same room as the BV5. Perhaps the BLC needs to be set as an Audio Master, then using Option 0 as the ML Option, that I believe turns the speakers off in the local room and should allow for the Moment to play through the ML linked BV5...That is if the BV5 is set to see a ML Audio Master in the same room. Note that also the Moment may also need its speaker cover removed and a switch triggered in Speaker setup -> Use TV speakers or similar settings in the interface.
Cheers Beoaus
