Hello,
I'm looking for an SPDIF / Analog (tRCA or DIN) converter with a remote volume control (IR or RS232).
is there a brand that does this ?
Hi
SPDIF / Analog converter with IR remote control of volume.
https://www.aliexpress.com/item/32919437736.html
Another solution would be to use a ‘line level volume controller’ like this:
https://www.amazon.com/MCM-CUSTOM-50-8394-CONTROL-IR/dp/B01CX82KH2
and add that to a DAC of your choice.
Please notice, that you can find other solutions/devices on the linked site:
And be aware, that these converters only support a 2-channel PCM signal.
Could be interessant ! Thanks MM
Thanks but I miss a "small detail"
For 5.1 !
How about a small simple AV / surround preamplifier? It should do the job very comfortable.
