H9i - Popping During Take-Off
Earle
Posts 223
Earle Posted: Thu, Sep 26 2019 6:51 PM
I travel semi-frequently for work, and I've noticed that during take-off my H9i's do a bit of popping. Needless to say, it stops once we're well off the ground.
Anyone else notice this? Is this due to change in cabin pressure? Or maybe it's the ANC trying to sort out the loud rumble of the plane as the engines rev up for take-off?
I hear the same pops during landing, which is when the decibels reach their highest, so I'm leaning more toward the ANC having a difficult time trying to work out what's up.
leosgonewild
Helsinki, Finland
Posts 2,373
I believe you answered the question yourself Wink
ACN is for blocking noice, not sound.
SpeedingGuy
Posts 4
I also heard the popping sound, I think that its when the sound for the noisecanceling  is to loud this happens and what you hear is simply the clipping of the mics!
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
