Does somone have the Usb Servicetool mk2 for the beomaster 5?
I would like to use it now my beomaster 5 is dead and ill want to replace the motherboard.
Hi, i don't know your specific problems or requirements but in general it may not be too complicated to repair the motherboard.
If you swap it, do you already have a new motherboard ? Because those aren't easy to find in my experience.
But if you have, just place the bios chip and the HD from the old to the new board an you're done, no need for a service tool.
I have an epia ex15000, thats overclockeble to 2ghz but my old bios is also broken (grilled for life). Thats wy i need the usb to set things back
Better leave it at 1,5 GHz, not too much difference.
Put old BIOS chip in new Board and load defaults.
That should be all.
Ralph-Marcus
The old bios chip is broken, thats wy i need service tool usb
https://archivedforum2.beoworld.org/forums/p/17311/218237.aspx#218237
That link is not working anymore, i tried that allready
ipaul:but in general it may not be too complicated to repair the motherboard
