Config tool 6.00 and Windows 8
This post has 13 Replies | 4 Followers
Boem
Holland
Posts 66
Boem Posted: Tue, Dec 11 2012 10:38 AM
Hello Everyone,
The 6.00 ct works well with Windows 7 64 bit and Beo6
Now I have windows 8 on my computer and he says he can not install the driver
I get the error Failure microsoft-INF does not contain digital signature information
Anyone here knows a solution
I also looked up how digital signatures can circumvent but can not find it
Have to Windows helpdesk called but who say I should inform manufacturer
Help does anyone know a solution for that problem
Have been a couple of days to search
Greetings from Boem
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
B&O's does not have have their driver digitally signed which means you will need to install it manually.
In true Microsoft style it makes it very difficult (but not impossible) to bypass "Driver Signature Enforcement"
Unlike all other versions of Windows which support digitally sign drivers to bypass the enforcement system can ONLY be done in the operating system "Startup Settings"
Here is the procedure which assumes you are logged into Windows 8
  1. Press WIN + I to launch the CHARM BAR and click Change PC Settings at the bottom.
  2. In General scroll to the bottom of the page, click "Restart Now Button" under "Advanced Startup" section.
  3. After Windows 8 reboots click "Troubleshooting"
  4. Then Click "Advanced Options"
  5. Now Click "Startup Options"
  6. The forth item down in the list is "Disable Driver Signature Enforcement"
  7. Click the Restart Button and a new menu will appear after it reboots
  8. Press either the "7" key or "F7"
  9. Now you will get the Window which you would normally see on earlier versions of Windows to allow you to bypass signature enforcement
Regards Keith....
Griebel
Posts 416
Griebel replied on Tue, Dec 11 2012 10:18 PM
Keith the 'saver'... as usual I must say.
I don't get it. Everytime a new OS is released, it's a real pain to install the ConfigTool.
I dream of a world of full compatibility!
Boem
Holland
Posts 66
Boem replied on Wed, Dec 12 2012 8:59 AM
Keith,
You are really incredible, it works
In a few minutes gefixt in Windows 8
Lucky there is Beoforum
Thank you very much
Greetings from Boem  Smile Big Smile Smile
TWG
Posts 1,672
TWG replied on Fri, Jan 18 2013 2:03 PM
As I still have a Beo 5:
Will this work for the older Version of the config tool, too?
Thanks. :)
Keith Saunders
Posts 5,495
Yes, it should be the same for older versions.
Regards Keith....
IngvarW
Sweden
Posts 38
IngvarW replied on Sat, Jan 19 2013 10:00 PM
In both Wista and Windows7 my version 6 of the tool crashes when it reaches the Logopart. Any suggestions? I have reinstalled it from scratch without any result. In W7 its also problems with the USB-driver. Why is it always problems with B&Os software?
Brgds Ingvar
Current; Beosound 2, BV Horizon 48,  2*BL3, BL11, Beolit 12, Beolit 15, Beoplay P6, Beoplay A9, Beoplay H9i
Earlier; BV 10-46, 2*BL3, BM5/BS5, BS9000, BL8000, BV7-32, MX7000, Beoport, Beocord 8000, MX4002, BL2000, Beocom1, Beotalk1200
mariuszf1
Spain
Posts 12
mariuszf1 replied on Wed, Feb 6 2013 11:36 AM
Hi, could you provide a link for CT 6or 5.12 for me? my beo6 does not work with the 4.11 and i am going crazy to find the newer versions in the web, its hopeless.... thanks in advance
Mariusz
mariuszf1
Spain
Posts 12
Mariusz
beojeff
USA
Posts 2,012
beojeff replied on Wed, Feb 6 2013 4:01 PM
Does the configuration tool need Windows 8 Pro, or is just the standard Windows 8 sufficient? The only thing that I need Windows for is for the B&O configuration tool.
Ypeij00
Posts 34
Ypeij00 replied on Fri, Feb 8 2013 12:04 PM
Beste Boem,
Waar heb jij de CT6.00 vandaan geplukt? Ik ben al enige tijd op zoek gezien mijn 5.12 niet meer download naar mijn BEO5 en BEO 6.
Dave
Keith Saunders
Posts 5,495
beojeff:
The short answer is NO
Regards Keith....
beojeff
USA
Posts 2,012
beojeff replied on Fri, Feb 8 2013 7:50 PM
Keith Saunders:
beojeff:
Keith,
Could you please clarify? Are you saying that I need to buy the Windows 8 Pro instead of just the standard Windows 8? As I said, I would only be buying Windows for using the configuration tool. The "Pro" version is double the cost.
jans
Belgium
Posts 394
jans replied on Mon, Feb 11 2013 9:13 PM
I have the same problem! The tool is very unstable and crashes often. I am running CT6.00 on a Windows7 32 bit set-up.
Any suggestions how to resolve this?
Jan
Page 1 of 1 (14 items) | RSS
DigiCert Secured Site Seal
