B&O's does not have have their driver digitally signed which means you will need to install it manually.
In true Microsoft style it makes it very difficult (but not impossible) to bypass "Driver Signature Enforcement"
Unlike all other versions of Windows which support digitally sign drivers to bypass the enforcement system can ONLY be done in the operating system "Startup Settings"
Here is the procedure which assumes you are logged into Windows 8
Regards Keith....
As I still have a Beo 5:Will this work for the older Version of the config tool, too?Thanks. :)
Yes, it should be the same for older versions.
In both Wista and Windows7 my version 6 of the tool crashes when it reaches the Logopart. Any suggestions? I have reinstalled it from scratch without any result. In W7 its also problems with the USB-driver. Why is it always problems with B&Os software?
Brgds Ingvar
Earlier; BV 10-46, 2*BL3, BM5/BS5, BS9000, BL8000, BV7-32, MX7000, Beoport, Beocord 8000, MX4002, BL2000, Beocom1, Beotalk1200
Hi, could you provide a link for CT 6or 5.12 for me? my beo6 does not work with the 4.11 and i am going crazy to find the newer versions in the web, its hopeless.... thanks in advance
Mariusz
Does the configuration tool need Windows 8 Pro, or is just the standard Windows 8 sufficient? The only thing that I need Windows for is for the B&O configuration tool.
Beste Boem,
Waar heb jij de CT6.00 vandaan geplukt? Ik ben al enige tijd op zoek gezien mijn 5.12 niet meer download naar mijn BEO5 en BEO 6.
Dave
beojeff: Does the configuration tool need Windows 8 Pro, or is just the standard Windows 8 sufficient? The only thing that I need Windows for is for the B&O configuration tool.
The short answer is NO
Keith Saunders: beojeff: Does the configuration tool need Windows 8 Pro, or is just the standard Windows 8 sufficient? The only thing that I need Windows for is for the B&O configuration tool. The short answer is NO
Keith,
Could you please clarify? Are you saying that I need to buy the Windows 8 Pro instead of just the standard Windows 8? As I said, I would only be buying Windows for using the configuration tool. The "Pro" version is double the cost.
I have the same problem! The tool is very unstable and crashes often. I am running CT6.00 on a Windows7 32 bit set-up.
Any suggestions how to resolve this?
Jan
