Beocord 2200 squeal.
This post has 7 Replies | 2 Followers
happyman
Posts 7
happyman Posted: Tue, Dec 11 2012 12:12 PM
Hi - when I switch the Beocord on there is a sqeal which seems to be associated with the motor - i.e. a mechanical squeal not a "sound" squeal. Before I "dis-assemble" has anyone any suggestions. Will be gratefully received. I am a COMPLETE non-techy. Thanks.
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Dec 11 2012 9:59 PM
Yes, the motor needs lubrication. That one is easy to work on, just mark the different parts before opening it. Everything is screws together.
If the magnet is in the wrong position, the motor will turn the wrong way around...
Do not use any old oil, but special sintered brass bearing oil (Mobil DTE). Steer clear of 2in1 and WD40!
You will also need new belts. I believe only Dillen has them, although I'm not sure his kit is finalized.
Jacques
happyman
Posts 7
happyman replied on Wed, Dec 12 2012 5:48 PM
Thanks for that Jacques - was just about to wd 40!!!! Will take your advice......... what would you use as switch cleaner for old volume control of Beomaster 1600 which is a bit!!!! scratchy?Thanks a lot.
Søren Mexico
Mexico City
Posts 6,411
happyman:
Wash out with iso alcohol, when dry apply Deoxit and move over full range a couple of times, leave for 5-10 min, clean again, let dry, done.
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Dec 12 2012 6:00 PM
The best you can do is taking it apart to clean it. I'm afraid anything else is illusory. As said before, just spraying will work for a while... or not!
Søren Mexico:
That will work, yes, Søren. For some time? But then if you really want to do it properly, you know what to do! Of course, it's much more difficult. But a 1600 is not a 4400 Angry, so I reckon it's quite feasible.
By the way, Søren, what's up?
Jacques
Søren Mexico
Mexico City
Posts 6,411
chartz:
Absolutely, take them out, and then, depending on type, take them apart, but some types like BM 901, BM 4/4000, are open enough to clean without taking them apart, on these I use iso alc. and a pipe cleaner, and really wash them out, the Deoxit (not spray) from a bottle, on a pipe cleaner will clean of oxidation.
And I'm waiting, waiting for my parts for BM 4400, BG 1202, and wating to go up to McAllen TX to pick up BG TX2, Bvox P45s, and some more tools and small pieces. The parts from DK was send 4 weeks ago, may take up to 6 weeks, thanks to Mexican customs, and it drives me crazy.
I hope the P45s comes without loose magnets, but if yes, it will be an interesting job, the TX2 looked like a wreck, so also there, a lot of fun before that one will be up and working, it comes with a broken MMC2, so I will have to do some negotiating with Axel, to change it with a MMC4.
When the DK parts are there, I can get my BM 901, Bvox 1600 and BG 1202 set up, will look beautiful together. And then back to the BM 4400
So I'm doing absolutely nothing, just waiting, waiting, well, I did make a database for all my B&O, bought where and when, prize, S/N and type,
MODEL TYPE SER. NO. ORIGIN DATE PRICE
Beomaster 901 2602 132031 Eb. San Francisco US ago 26, 2010 USD 20.00
Beomaster 2400
Eb. Chicago US Sept 12, 2010 USD 99.95
Beomaster 4000 2408 274148 Eb. Tacoma, WA, US abr 8, 2011 USD 103.50
Beomaster 4400 2419 1408008 Eb. Dallas, OR, US jul 6, 2012 USD 51.00
Beomaster 5000 (83-86) 2323 3178113 Eb. Pikesville, MD, US mar 13, 2012 USD 202.50
Beosound 3000 4923 16140284 B&O Aarhus, DK ago 15, 2002 Dkr 13,000.00
Beogram 1202 5237 57115 GG. Tørring, DK may 5, 2012 Dkr 200.00
Beogram 2404 5763 2851053 Eb. Ft. Lauderdale, FL, US jun 5, 2003 ???
Beogram 5000 5804 3099038 Eb. Minneapolis, MN, US Sept 9, 2010 USD 177.50
Beogram TX2
Eb. Orange, CA, US oct 19, 2012 USD 50.00
Beogram CD50 5113 4046972 Eb. Dallas, TX, US feb 4, 2012 USD 25.00
Beocord 5000 4923 3115072 Eb. Dallas, TX, US feb 4, 2012 USD 25.00
Beovox S45 (83-86) No Lost Eb. Seattle, WA, US ago 30, 2010 USD 40.00
Beovox 1600 6219 56788 Martin, DK jun 10, 2012 Dkr 300.00
Beovox 3702 6263 Coming Eb. Olmsted, OH, US dic 12, 2010 USD 85.00
Beovox 3000 Panel 6716 6841057 Jaff Bay, US ene 5, 2011 USD 300.00
Beovox P45 6307 716447 Eb. Glendale, AZ, US ago 11, 2012 USD 120.00
Beolab 4000 6638 16138538 B&O Aarhus, DK ago 15, 2002 Dkr 12,000.00
Beolab 8000
Eb. San Francisco, US May 15, 2004 USD 2,200.00
happyman
Posts 7
happyman replied on Thu, Dec 20 2012 12:47 PM
Can't believe it - after all excellent replies I was about to buy all those "stuffs" for cleaning and to take a VERY deep breathe. Switched it on and before doing anything squeal just disappeared - completely! BUT will bear in mind your comments for future. Many thanks All!!! Merr Xmas - or whatever festivity you may celebrate in your culture.
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Dec 20 2012 1:57 PM
Probably the belt which finally engaged!
But then yes, a lubrication will be needed, as well as a new belt ;-)
Jacques
Page 1 of 1 (8 items) | RSS
